2005 Sportsmobile with UJOR Lift
Brad Kilby
I bought this rig in January 2014. The van was in Asheville NC and since I knew Chris from U-Joint Off Road, I had the van delivered there to transform this rig into what it is now. I bought this from the original owner who used it mainly for freeway travel (2WD). It had 157,791 miles when I bought it, I put on less than 5,000 miles since then. Asking $65,000. I’m sure I’ve left stuff out, please ask questions. Brad 818-631-0747 or PM. More pics added. If there's something specific you'd like to see, just ask!
Van Stuff:
EB 350
6.0 Diesel
162,635 Miles
3 Captain Seats, Front 2 Swivel (1 removable)
Seats 7, Sleeps 4 (seating 6 is more comfortable)
Kenwood Double Din with Sirius XM
Scan Gauge and Pyro Meters
Sportsmobile Stuff:
Modified EB48 floor plan. Full Walk Through! Lots of rear storage!
No Onboard Propane
Marine Grade Vinyl
Manual Penthouse.
Wabasto Air Top 2000 Furnace (Diesel)
Isotemp Slim water heater
Tripp-Lite RV2012UL Inverter (2000W, 100A Battery Charger)
Norcold 2.7 Cu. Ft. Fridge
Sink and Microwave
18 Gallons Fresh Water
Grey Water Tank
Yakima Roof Rack
Fiamma F45 Awning
Free Standing Table
Rear Ladder
Inside and Outside Showers
UJOR Stuff:
Everything listed here was done before I picked the van up. Less than 5,000 miles on this list of goods:
UJOR 6” lift
Bilstein Shocks
New Drive shafts (1350)
Sterling Full Float Rear Axle
ARB Lockers F/R
4.10 Gears F/R
RSC Upgrade with Larger Brakes
Maxis Bravo 315/70/17 Tires (5)
Centerline Wilderness Grizzly Wheels
ARB Compressor, Air tank, 2 couplings
Electric AMP Steps (the Ladies will love you for this)
Sears Die Hard Starting Batteries
Cam Position Sensor
OEM Engine Wire Harness
Ford FICM
Oil Temp Sensor
Alternator
Oil Cooler
Bullet Proof EGR Cooler
EGR Valve
SCT Tuner
Bushwacker Flares
Stuff Done Since UJOR:
2 Deka AGM House Batteries 07/2014
MAP Sensor
New Garrett Turbo (Installed 05-03-2016)
Oil Change and Filter (05-03-2016)
Aluminess Front Bumper with Shackles and Hi Lift Mount and Hella Lights
Warn 16.5 Winch
Exterior LED Light
2 Digital Volt Meters (F/R)
Door Galley Box
New Window Tint All Around
brianjwilson
Some sort of lost...
Looks like a nice rig! It doesn't fit my needs of forward facing seats for a toddler and infant, but I'm sure it wi make a great van for someone. Good luck with the sale!
poriggity
Now that's a good idea.. for those looking i have seen this rig in person and I've known brad for a long time. He takes immaculate care of everything he owns and this is a great rig!
Sent from my LG-H810 using Tapatalk
Smudge12
