Time to see my faithful friend go on more adventures.
Shes been great to me and will be great to you as well.
2006 outfiter caribou 8.0
True Composite Foam Core Roof
Fully welded aluminum frame
Torsion assisted lift system
Vacuum bonded composite walls
Solar reflective windows
3' 3 way fully insulated, properly vented refrigerator
Electronic ignition 16K BTU furnace
4 corner mechanical jacks
20lb LPG bottle with gauge
Power Vent System
24 gallon fresh water supply
Shurflo® electric water pump
3 burner high-output stove with Piezo ignition
45 AMP PD converter with trickle charge
Queen size cab over bed
Under-bed storage
LPG & Carbon monoxide detectors
Pressure fresh water fill
110 & 12 volt outlets
Maple interior doors
Washable curtains
CD player with AM/FM radio w mp3 hookup
Sliding cab through window
Camper anchor tie downs with centering guide
Wiring to truck, chain, and spring loaded turnbuckles
Screen door and keyed locking deadbolt
1 overhead storage cabinet
2 6 volt batterys
solar panel with required controlers
Pretty much an awesome time in the back of your truck, fits short or long box.
i took this down to the baja for a month on my last jorney and it worked great.
Fridge cooling element has been replaced and comes with a 5 year warrenty.
Will Deliver it within reason with a deposit and some extra gas money for one last trip camper is located in Nelson B.C Canada more photos available.
9000.00$
Would also consider selling the truck with the camper
its an 08 dodge ram laramie with 200,000KM not miles, off road bumper with warn m15000 winch freshly rebuilt. EFI live tune for economy, dpr removed, egr blocked. Has 35 inch toyo mt on it now.
email iliketosnowboard@hotmail.com
Power Vent System
Under-bed storage
Washable curtains
2 6 volt batterys
9000.00$
