2007-18 Jeep JK Wrangler rear shock and control arm skids
Rancho
Supporting Sponsor - Rancho Suspensions
If you have a Jeep JK/U Wrangler you know how low the rear shock and control arm mounts hang, but now with Rancho's NEW JK Rear Shock and Control Arm Skids that are designed to protect your Jeep JK rear control arms and shock absorbers from rocks and other obstacles. Made from 1/4-in. high-strength, low-alloy steel, these skids will glide over obstacles and keep you moving down the trail. The Rancho Rear Shock and Control Arm Skids bolt-on using the shock and supplied control arm bolts, and are powder coated in a durable Rancho Red. Driver and passenger side skids included.
Mounts to rear lower control arm and shock bolt
Constructed of durable 1/4-in. HSLA steel and powder coated Rancho Red.
Check with your favorite retailer on cost.
WonaWarrior
