FMF
SOLD
2007 Starcraft RT10
Good:
-Clean title in hand.
-All original documentation.
-We are the second owners.
-Always garage kept since new.
-Upgraded to two 6v golf cart batteries.
-Upgraded to 35 amp power converter.
-Interior lights upgraded to LED.
-Fully boxed frame.
-One piece solid roof.
-Great leaf spring and shock suspension (for a trailer).
-Tows like a dream.
-6 gallon propane hot water heater.
-Everything works needs nothing and is ready to go camping.
Not so good:
-The flip down counter with the sink and stove broke on us when we had it
out on a trail. We added a piano hinge and built a new frame for it but the
nail heads are slightly visible.
-Porch light cover was cracked but has been glued and works as it should.
-If you go to a campground everyone will stop by and ask you questions about
it.
2008 Starcraft RT 10RT Specifications
--Wheels & Tires:
Wheels Composition Aluminum
Number Of Axles 1
Rear Tire (Full Spec) 15 Inch Wheels
Spare Tire Location Exterior Mounted
-- Brakes:
Rear Brake Type Electric Drum
-- Technical Specifications:
Length (closed) (in/closed) (mm/closed) (m) 159 / 4038.6 / 4
Width (in/mm) 86 / 2184.4
Interior Height (in/mm) 77 / 1955.8
Length (ft/ft) 20
Length (ft/in) 6
Height (closed) (in/closed) (ft/closed) (mm/closed) (m) 67 / 5.6 / 1701.8 /
1.7
Dry Weight (lbs/kg) 2066 / 937.1
Payload Capacity (lbs/kgs) 1602 / 726.7
GVWR (lbs/kgs) 4000 / 1814.4
Hitch Weight (lbs/kgs) 203 / 92.1
Capacities Standard
Number Of Fresh Water Holding Tanks 1
Total Fresh Water Tank Capacity (gal/l) 35 / 132.5
Propane Tank (s) Standard
Number Of Propane Tanks 2
Total Propane Tank Capacity (gal/lbs) 9.4 / 40
-- Exterior:
Body Material Wood
Sidewall Construction Aluminum
Number of Doors 1
Sliding Glass Door No
Expandable Bunk Material Soft Shell
Number of Awnings 1
Awning Length (ft/m) 9 / 2.7
Leveling Jack Type Front Manual / Rear Manual
Roof Vents Standard
Propane Tank Cover Standard
Outside shower
Outside propane grill
-- Identification:
Generic Type (Primary) Expandable Trailer
Manufacturer Country USA
Regional Availability All Regions
Display Name RT 10RT
-- Heater & Cooler:
Heater Type Propane Automatic
-- Other:
Carbon Monoxide Detector Standard
Propane Alarm Standard
-- Electrical:
Battery Power Converter Yes
Battery Converter Amps 35
Air Conditioning Prewiring Yes
Cable Prewiring No
Phone Prewiring No
Heat Prewiring Yes
TV Antenna Prewiring No
Satellite Prewiring No
Washer / Dryer Prewiring No
Exterior Plugs Standard
Ground Fault Plugs Standard
--Lights:
Exterior Flood Lights Standard (LED)
--Paint & Finish:
Metallic No
Wallpaper Yes
Curtains / Shades Standard
Interior:
Kitchen / Living Area Flooring Type Vinyl
Kitchen Table Configuration Bench Seats
Kitchen Location Center
Living Area Location Center
Number Of Oven Burners 2
Layout Stove
Refrigerator Size Compact
Refrigerator Power Mode Electric / Propane
Max Sleeping Count 6
Number Of Double Beds 1
Number Of Queen Size Beds 1
Number Of Convertible Beds 1
Sink / Faucet Standard
Power Vent Fan Standard
2007 Starcraft RT10
Good:
-Fully boxed frame.
-Tows like a dream.
Not so good:
it.
--Wheels & Tires:
Number Of Axles 1
-- Brakes:
Length (ft/ft) 20
Length (ft/in) 6
1.7
Capacities Standard
-- Exterior:
Body Material Wood
Number of Doors 1
Number of Awnings 1
Roof Vents Standard
Outside shower
-- Identification:
-- Heater & Cooler:
-- Other:
-- Electrical:
Cable Prewiring No
Phone Prewiring No
Heat Prewiring Yes
--Lights:
--Paint & Finish:
Metallic No
Wallpaper Yes
Interior:
Layout Stove
