2008 Hummer H3 Alpha
JPaul
Last steps are to actually install it on the Alpha. Seeing how the whole thing is made with 3/16" steel it now weighs a fair bit. I'm glad I pulled the winch off, because just the bumper and the winch alone were barely light enough for me to handle on my own. I would not have been able to lift it by myself with the pods and the winch attached.
Ready to go on:
And bolted in place:
Winch mounted, cover put on the winch, grille installed, and license plate mounted to the clip on bracket I made the first go around using a few old plates as backing and Maglite clips to attach it to the fairleade rollers. This time around I finally added the license plate protector I bought ages ago to help keep the plate nice. Since these are my callsign plates, I'm going to be a bit pickier about keeping them in good shape. The winch is a 12K pound Badlands winch I picked up shortly after I first got my red H3, I snagged it for just $200 during a Harbor Freight parking lot sale, it was an open box item they had discounted by $100, and since they were selling brand new ones for $300, they knocked this one down to $200.
A shot of it outside:
If the truck looks lopsided, that's because it was. I had messed around with the torsion bars when I first got it and had to change out the axle. Somehow the front had ended up at about 26" from center of wheel to bottom of the fender. It really should have only been about 23.5" at most. Not sure how it happened, but I think that is what lead to the failure of the CV boot. At any rate, once I had the bumper and winch all on there I went ahead and re-leveled it. Now it's sitting right at 23.5" center of wheel to fender which is about perfect.
The winch isn't fully hooked up yet, I just need to attach the cables to the battery, but I have some military terminals sitting here that I just got from Amazon to replace the stock ones. The stock terminals on these are known for causing issues, and I had already replaced the ones on my red H3 with some brass terminals I had on hand. I've also wondered if on the Alpha they are causing weird issues because my Ultragauge has intermittently been showing the voltage at around 12.9 volts instead of 14 volts or so while driving. I'm hoping the new terminals will correct that. No codes or anything have been thrown because of it yet at least.
JPaul
After dinner and getting the girls in bed I spent some more time on the Alpha, this time installing the Tekonsha P3 brake controller I picked up. At first I mounted it on the left of the steering wheel, but that ended up being a bad location because my knee would hit it while getting in and out of the truck.
So the next step was moving it over to the right side, but I put it up fairly high and then discovered that it was in the way of the ignition. Oops.
So I moved it down lower which worked out better anyway because I could see the screen a lot better through the steering wheel, and I can rest my hand on my knee and be able to manipulate the controls as well as the manual brake lever.
It's a good thing I went with the P3, because right off the bat after getting the wires crimped together with the OEM pigtail, it started complaining about the brake line being shorted to ground. I noticed that it wouldn't always do it and would clear after a random period of time, but then come back up with that warning. I wracked my brain trying to think of what could possibly be causing an intermittent short to ground for the trailer brake wire, then finally remembered and issue others have had with the harness at the rear bumper rubbing against the body and shorting out.
Opening up the gate and looking down at the harness and sure enough, it was rubbing through. Bummer. I didn't have this issue on my red H3, it cleared it just enough to not be a problem, and I added some insulation to it in order to prevent it from happening later. Guess it's too late on the Alpha. The brake wire is rubbed through enough that it really should be repaired or replaced.
JPaul
Since the popup tent trailer I'm taking down to Moab has brakes, I have to get that fixed pretty soon. I need to see if I can just get a new harness or if I should just repair the line. Honestly with where it is at it wouldn't be too bad a job to cut the wire and crimp it back together, or just crimp a ferrule right over it to restore the effective gauge of the wire.
Another issue I discovered is that the transmission lines running into the cooler in the radiator are leaking at the quick connect fitting where the lines enter into the fittings. It's a brand new radiator so I'm pretty surprised at that. Right now my options are to either try pulling the lines out and seeing what's causing the leak and if it's possible to fix it (unlikely), replacing the radiator (which is stupid seeing how it's basically new), or bypassing the in-tank cooler completely and adding an external stacked plate cooler. Honestly the latter is probably going to be the route I take. I've thought about doing that for the red H3 for a while now, and since I'm definitely going to be hauling a trailer around now when going camping, I'm probably just going to be better off with the external cooler.
On a happier note, I moved the majority of my stuff I keep in the back of the H3 (my recovery gear, some tools, straps, rope, etc) from the red H3 and the bags they were (mostly) all in to the MTM crates I bought and have them all in the Alpha now. I still need to go through them and re-evaluate what I really need/want to keep in there, but at least now I have most of my stuff in the Alpha.
I still need to move the ARB fridge over, but I'm probably going to wait a while longer until I see if I can get the rear power all installed. I have a 2/0 15' cable coming on Tuesday for the main supply to go from the battery in the engine bay all the way back to the rear pillar on the driver side. I also have a couple 2/0 cables coming to provide the ground path, I'll have a cable up at the battery going to the frame, and the other will be at the back pillar down to the frame. I have a Blue Sea SafetyHub 150 on the way as well to provide power distribution for the rear. This way I can wire in my ARB twin compressor in the rear, as well as my 750W inverter and my ARB fridge. My Icom 706MkIIG is probably going to go back there as well, I have the remote cable and bracket for the head so I can have that up front. The only place I could think of up front for the Icom's body was under my seat, and I just don't like the idea of having something like that low down where it runs the risk of getting wet (in case of a deep water crossing or something, like the sunroof leaking).
I spent a lot of time trying to figure out what kind of power I wanted in the rear, and ultimately determined I wanted to be able to have a minimum of 150 amps supplied with no more than roughly 3% voltage drop, and theoretically the 2/0 cable will provide that. Even if it's more like 4% I'll be happy with that. Then all my accessories in the back will have plenty of power and can run as efficiently as possible. With the cables, fuseblock, fuses and other items I'm only spending about $250 for the whole setup thanks to some good deals I landed.
JPaul
So I got the 15' cable in today, and wouldn't you know it, the seller apparently doesn't know the difference between 2/0 gauge cable and 2 gauge cable, even when 2 gauge is all that is printed on the cable jacket... :rage:
I messaged them though and they gave me a call about it. They are going to send me a 3/0 gauge cable that is 18' long instead and let me keep the 2 gauge cable as well. So that's pretty good service right there. Now my current capacity will be even better with almost no voltage drop. I also might be running the cable on the outside now along the frame rails instead of through the body. We'll see how it all really fits. I'm a little bummed though because now I want to get some 3/0 ground cables to match it instead of the 2/0 I bought, but that's going to have to wait until later, if I even decide to really change that part of it.
JPaul
And now we're current.
This past week I have received a bunch of goodies that I've ordered for the Alpha with still some more on the way.
JPaul
So Saturday was spent fixing the two major issues that have come up that needed to be addressed before my trip to Moab at the end of the month.
First up was the trailer brake wire that had rubbed through. I had to pull the bumper off to make this easy, and after that it really wasn't too bad a job other than having to run out to find some Deoxit. (Guitar Center ended up having some, interestingly enough)
Here's a better shot showing the damage:
Fortunately the two wires next to it ended up being OK, I thought they had also been rubbed through the insulation.
This is supposed to be 12 gauge I think...
Apparently I expected too much from Deoxit, I was expecting it to actually remove the blackening on the copper wire (which occurred from the copper being exposed to the elements after the insulation was rubbed through), but it didn't really seem to do anything. So I fanned out the wires and used a bronze fine bristle wire brush and scrubbed them clean:
The Deoxit probably helped, and should help protect the wire as well now.
JPaul
Once the wire was cleaned I spliced it together using a crimp that has adhesive lined heat shrink. This will make it a permanent fix and seal out the elements.
Then I wrapped it using some 3M self vulcanizing rubber tape. Frankly it's all I had on hand, I have no idea where my regular electrical tape is and didn't want to waste more time looking for it, but I think this is better anyway as it adds quite a bit of buffer between the wires and the body now.
And here it is back in place. It still rubs against the body, and while I could have left it loose instead of clipping it back onto the bumper I was concerned about it ending up rubbing against some other edge later on. I modified the mounting clip though so that it allows the connectors to angle down, now it still rests against the body but it isn't exerting very much pressure at all against it, so it should last quite a while. I'm going to make sure to inspect it periodically to make sure it's not still an issue.
JPaul
I also took a quick moment to finish hooking up the brake controller, now that the wiring was fixed. It's much happier now.
JPaul
Something I thought I'd take a shot of and share, the H3 has a great spot for a flashlight right next to the seat. I don't even use clips since I've never had this one roll anywhere. It's a worklight from Lowes (their Kobalt brand) that uses Lithium Ion batteries and has the charger built into it (including the plug that goes into a 110v outlet), and it came with a AA battery box as well so I can have that spare. I use this light for all my work on the truck, through honestly I really should by a proper worklight, while this does last all day, it'd be a lot nicer to have one that just plugs into the wall.
JPaul
On to the next fix, the transmission cooler. When I crawled under the Alpha again yesterday to start on this, I noticed that even though I had wiped the bottom of the radiator clean the weekend before, it was already sopping wet with lots of drips forming of transmission fluid. I was able to determine that it was in fact coming from the passenger side cooler line where it entered the radiator. I think it had actually gotten worse since the week before.
So to start, I made some measurements to see how the Long transmission cooler would fit, and determined I needed to move the AC line again. This time I put it back out in front of the nose and zip tied it along the bottom. That will keep it out of the way of the winch.
After a fair bit of test fitting, determining where to attach the brackets, how to run the cooler lines, etc, I finally landed on this location. Fortunately there ended up being pre-existing holes I could use on the body for all four brackets.
You'll notice I also pulled off the winch control box from it's previous location, partly to facilitate the installation, and partly because I decided with the addition of the transmission cooler and a bigger engine so it's going to go on top of the winch instead. I did a test fit and found that the grille just barely fit with the control box on top of the winch.
JPaul
At this point I went ahead and redid the routing of the winch power cables and mounted the controller. Previously I was passing the power cables up at the uppr right through the same hole the AC line ran through, but then I noticed a second hole on that same side lower down. This was more favorable since then I didn't have to worry about the power cables rubbing against the AC line. A few cuts with my knife and the cables routed perfectly.
They still aren't hooked up yet, I want to swap out the batter terminals first. That should happen this week sometime.
JPaul
Next up was plumbing the lines. I removed the factory hose crimps from the hard lines next to the front of the engine and pulled the hoses off. Since the stock cooler lines turned out to be aluminum (which made it a lot easier to use the flaring tool with) I cut up the portion I removed that ran into the radiator to use as 90 degree bends.
Then I cut off the ends that went into the radiator and turned them into plugs to help prevent future contamination or leaking of coolant if somehow the cooler that is still in the radiator develops a leak.
Then I plumbed the lines using the hose provided in the kit and some fuel injection clamps. The hoses drop down under the radiator and below the sway arm and back up to the hard lines that run back to the transmission. I made sure to plumb it so that the fluid flows from the bottom of the cooler to the top to prevent air pockets. The hoses do rest on the skid plate though, so I want to try and figure out a way to keep that from happening so that they don't rub through. I also want to get some split loom that is big enough to go around the hoses to help protect them. All the split loom I have right now is too small.
And all buttoned up. I finally finished this all up at 3AM Sunday morning, mostly because I was being extremely particular about everything and trying to make sure this was as optimal as I could make it. I wanted it to be a once and done deal, rather than rushing it and then having to go back later and redo it. I do still want to go back and pull the brackets off and paint them black so that they blend in, and probable replace the hardware with stainless steel, but that's all minor tweaks.
The transmission cooler is a Long 4590, it's supposed to be good for up to 28,000 GVWR but as an add on cooler to the factory cooler. Since I'm completely bypassing the factory cooler I wanted to make sure I had plenty of cooling for the transmission, particularly since I have lots of mountains around here and will be towing a trailer more frequently. It's supposed to have a built in bypass, but if I find that it's overcooling (particularly during winter is my concern) then I'll add in a thermal bypass later on. I also picked this one up for just over $80 shipped, so why not?
JPaul
So it's been raining since yesterday afternoon, and this morning I came out to the truck to discover a puddle of water in my Huskyliner floor mat on the driver side. Further inspection revealed that not only is the carpet underneath completely sopping wet as well, but the same thing happened on the passenger side. This means my sunroof drains are either blocked, or more likely the lines came off somewhere on each side since it was dripping down from the sides and there is not a pool of water in the sunroof tray at all.
Just what I need after spending all that time cleaning and drying the carpet just a few weeks ago, especially right before my Moab trip. Fortunately the weather forecast has it dry after Monday. Unfortunately until Monday the forecast is more rain. I think I might put duct tape over the sunroof seam in the meantime to stop the flow of water. I'm not going to be able to work on this until after the Moab trip, I've been swamped at work and still have a bunch of stuff to get done before the trip.
bknudtsen
Open the hood and check either end of the windshield well. Look for a flapper style drain (like a rubber trap door) and stick your fingers in to check for pine needles and debris. My old ‘07 Chevy 2500HD leaked as you are describing and it turned out that the drain tubes were blocked at the exit point by debris and would back up under heavy rain. I used a hose to flush the windshield well. You can feed a stiff weed eater line down the drain tubes from the sunroof end to clear out any debris that might be in there.
Part way down the page:
http://forum.expeditionportal.com/t...evrolet-2500HD-Project-quot-Agnes-quot/page14
Also, open your sunroof and check for cracked tracks. If they are cracked, you might need to press down on the rear glass as you close the sunroof to get it to seat fully.
Brad
JPaul
The issue with the sunroof drains on the H3's is well known in that community. They drain behind the wheel well liners I believe since usually everyone will pull them out from the inside to work on them, you cannot access them from the engine bay. I was going to fix it when I had the carpet out, but ultimately never got to it. Now I wish I had made sure to spend the time on them, though I probably wouldn't have caught if they are disconnected then.
rumpityz28
