2009 Loaded Horizon Adventure Trailer
smokey
Lowered Price to $14,500
Specs: Horizon Trailer-OD Tan Color with black Chassis.
- Fuel can set-two with AT trailer Holders
- Water Tank-19 gallon roto mold with 1.25" opening, 1/2" drain plug with
pump.
- 12v power-Aux 12v power lighting w/night light, ARB Adventure light, with
THREE fused outlets, batttery tray and hold down.
- TWO (2) Batteries: Valvle regulated AGM Group 31 deep cycle battery 105 AMP.
- Power tender Dual: Noco marine series On board Amp (10/10) dual battery
charger & maintainer shore plug.
- RV-20- Carmanah RV-25 AMP Solar panel Charge Controller and surface
mount (I would like to keep the solar panel unless buyer wants to purchase)
- Electric braked Axle upgrade with 10" drums, includes break away kit.
- max Coupler-multi-axis coupler, 3500 lb. Class 2.
- Horizon kitchen- slide out 2 burner stove, cutting board, compartment
dividers, 11 lb. propane cylinder and bracket (two propane tanks).
- 6x6 F-35 Awning and telescoping brackets. (one of the caps on the end is cracked, but still fully functional)
- Globe trotter roof top tent
- Engel 45 liter fridge/freezer
- Insulating transit bag for Engle fridge
- slide for Engle fridge
- Jeep Rubicon rims with pro Comp 35" AT Extreme" tires
- Stainless steel sink with mounts.
- Maxxima 6x1 watt LED haevy duty work light
- marine outlet- 12volt marine grade power outlet, locking type.
- TWO Manchester 11 pound propane cylinder & bracket
This is low miles, garage kept (except for this summer/ had to make room in the garage!)
was rolled on its side once and sustained a few scrapes, gravel paint chipped in front but great condition
It is awesome, as you know if you are familiar with AT horizons.
Email me g_breetz@hotmail.com
Thanks!
Gary
smokey
smokey
Rolled once on this side. No major damage just some scratches and plastic fiamma end cap broke off. Still as functional as new. I think of it as a tribute to the structural integrity of AT horizons. I've been thinking of getting a pvc pipe end for to replace the cap.
JCCB1998
