B350
2010 Ford E450 4x4 6.0L PowerStroke Diesel
ONLY 21,620 miles!
Super clean, rust-free, low mileage, all original van. The van reflects the low mileage and looks and drives like new. It was just retired from a small municipality where it was part of the search and rescue squad. Everything inside and out is clean, clean, clean. It’s as close to new as you’ll likely see.
Van Specs: (VIN: 1FDXE4FP1ADA16564 )
The following are points of full disclosure regarding items affected by the ambulance conversion:
For those who are not familiar with the Ford 6.0L in vans- educate yourselves before listening to all the horrible bs people have to say about this engine without any real knowledge about it or experience with it. The 6.0L in the vans is slightly different that the 6.0L found in the F-series truck. By 2010 (last year for a 6.0L in a van) all the most prominent issues were ironed-out making this the most reliable year of the 6.0L PowerStroke. It does require regular maintenance but, not $6,000 in “bullet proofing.”
The van is located near St Cloud, MN 56303. I'd be happy to pick up any potential buyer at the Minneapolis airport. The van can be driven cross country as it is without a problem.
Asking $22,000.
Shop around, you likely won’t find a van this clean with just over 20,000 miles and 4x4. If you do, definitely get it.
Call or Text or DM
763.297.0450
Recent edit added GVWRs
ONLY 21,620 miles!
- E450 Super Duty chassis, 158” wheelbase
- Power locks, windows, mirrors, cruise control
- 6.0L diesel with dual 120 amp alternators and engine block heater
- Advanced 4x4 conversion with Dana 60 axles (4.56 gear ration), Warn manual locking hubs, Rancho shocks (RS 999115), front and rear sway bars
- 5R110 TorqShift 5-speed transmission, NP273F transfer case with floor shifter
- Fresh oil change with fully synthetic Rotella T6 and WIX filter, fresh transmission fluid as well
- Custom bug screen cover for grill/radiator
- 55 gallon fuel tank
- Ford Spec'd Weights:
- GAWR - Front 5000 lbs (spec given in 2wd trim)
- GAWR - Rear 9500 lbs
- Curb Weight - Front 3512 lbs
- Curb Weight - Rear 2558 lbs
- GVWR - 14500 lbs
- GCWR - 20000 lbs
- There were marker lights in each of the fenders that were removed.
- The fiberglass cab-back was attached as a temporary fitment meaning it is not 100% sealed off at the floor and does not have a solid rear window.
- With the removal of the ambulance box the van’s 2 starter batteries were just placed in the cab. These can be mounted wherever someone decides to put them for a custom build.
- While the front tires are like new Firestone Transforce, 3 of the rear 4 tires were swapped out with tires that have very little tread. That leaves the option open for a set of more aggressive A/T tires to suite a build preference.
- There is one quarter sized hole in the roof where wiring for the ambulance box exited the cab. It is a clean cut, rust-free hole that is currently taped shut.
- Being the lines for the air-conditioning leading to the ambulance box were cut the air-conditioning in the cab currently does not work. These lines will have to be removed.
Asking $22,000.
Call or Text or DM
763.297.0450
