2010 patriot soft roader build.
jhill15
Well swapping my tires front to back didn't really help. I even loosened my axle bolt and beat with a rubber mallet to see if it would go back in. What should I Should look at next? Should I put my old Wheels back on or just go ahead and X that out considering swapping my pro comps front to back didn't help.
Sent from my LG-H900 using Tapatalk
jhill15
Yeah, try the stockers. see what happens.
I guess worst case if my stocks work fine I could swap the hankooks...granted if its the wheels to my stocks and get some spacers. Of its something to do with the pro comps being lug centric and not seating right on the hubs then I will have to have some custom hub centric rings made.
jhill15
As long as your using lug nuts that have the same angle as the wheel then you should be good and lug centric.
I bought the pro comp lugs so I should be good. First thing though I gotta replace those sway bar bushings. They are not even holding the sway bar so I am praying that it's some of the issue. Its the the only thing underneath there that's messed up.
kojackJKU
Autism Family Travellers!
Oh, another thing to check, see if the wheels are solid around the hub...if so, maybe the little clips that hold the rotor on are not letting the wheel flush mount to the hub.
jhill15
Good thing is Advanced Auto has those bushings in stock for $6 so I'm gonna swing by there on my to work.
That's a good thing to check for. I didn't even think about the setting flush.
jhill15
I was gonna order some better bushings but Advanced auto had the moogs for $6 so I went ahead and got them. Anything has to be better than the busted non existent ones that are on there now lol.
jhill15
How are ya making out?
Well a snow storm has rendered me useless!
I'm so ready for spring!!!! I was gonna knock it out tomorrow but...hopefully Saturday I will be able to get it done. I did however nab up some End links today.
kojackJKU
Oh yeah. We are getting hammered with that one tomorrow and sunday. YEY!....puke! Keep me in the loop to see if you find it. Also, are you ordering the alignment kits from RRO?
jhill15
We ended up just getting enough to make things gross outside. The temps rose last night and melted it just as fast as it put it down but now we are left with a cloudy cold mist...lame!
I looked into the rro rear control arms. Is that the only thing I would need? Or do they make something for the front as well?
kojackJKU
They do make alignment bolts. have a look on their site. I HOPE that happens here. but we are looking at 16-24" OF snow.
Clemtiger84
