High_Country
Hey guys,
I did search and found this thread from last month or so.
http://www.expeditionportal.com/for...ons-on-trail-tire-pressure?highlight=air+down
It was helpful, but I wanted to ask for a bit more focused or specific advice. I have a 2011 Ram 2500 crew cab turbo diesel 4x4. I specifically call out the diesel due to the weight they put on the front axle.
I'm getting ready to do a trip in southern colorado through one or more of the passes. I would like to air down PRIMARILY for occupant comfort, not so much for enhanced traction - they are mostly just rocky/bumpy trails.
The truck will not be significantly loaded (gear for a family of three - perhaps 700-800lbs) in the bed. I am running Toyo Open Country ATII's in 285/75/17 - E rated. NORMAL street tire pressures are about 55 on the front axle and 40 in the rear for 'light load' no trailer.
After reading the previous thread, I was thinking that 35 psi for the front and 25 psi for the rear might be a good balance between achieving some rider comfort vs the risk of rolling a tire off the bead or something. I do have on-board air and will NOT be driving at these pressures on the street. I will air back up.
I'll obviously throw a 'low tire pressure' warning light, but can deal with that.
Does that sound appropriate?
