2014 Silverado 1500 Retained Accessory Power
Joronimo
For anyone looking to get Retained Accessory Power (RAP) on a 2014 Silverado 1500 (or possibly others) there is a 1/2" male blade in the drivers side fuse panel that is on in RAP and running and off when the key is off. I searched all over for a good spot to to tap in and couldn't find anything until I saw this one. I thought I would share since it didn't seem to come up anywhere I looked including the GM upfitter guides.
On the drivers side fuse panel cover its number 49, just a 1/4" male blade. Allyou need a a female and you're good to go.
Joronimo
I think most do. The problem I had was finding a good place to get a signal to switch a relay. Looks like Chevy made it easy with this blade, usually you have to use a wire tap or fuse tap to get into the circuit.
Deleman
