haznavy
15 Passenger Extended (155” wheelbase and 244” overall length)
Seating: 1 driver and 4 passengers (all other seats removed to customize)
1-ton 4 x 4 towing platform
VIN: 1GAZGZFL8F1281341
Price: $58,000 OBO
Mileage: 60,000 (Still under 100,000-mile GM factory warranty)
Engine:
Duramax 6.6L V-8 turbo-diesel (LGH)
Displacement (cu in / cc): 403 / 6599
Bore & stroke (in / mm): 4.06 x 3.90 / 103 x 99
Block material: cast iron
Cylinder head material: cast aluminum
Valvetrain: OHV, four valves per cylinder
Ignition system: fast-heating glow plugs
Fuel delivery: direct injection diesel with high-pressure common rail
Compression ratio: 16.0:1
Horsepower (hp / kW @ rpm):260 / 194 @ 2800
Torque (lb-ft / Nm @ rpm): 525 / 712 @ 1600
Recommended fuel: diesel B20 capable
Maximum engine speed (rpm): 3450
Emissions catalytic converter, exhaust gas recirculation; diesel particulate filter system (DPF), selective catalyst reduction (SCR)
Transmission:
Hydra-matic 6L90
Type: six-speed heavy-duty electronic automatic with overdrive and torque converter
Gear ratios 1)
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Final drive ratio (1): 3.73 (6.6L) (upgraded from the 3.54 standard option to improve towing performance)
Tow rating: 9,700 lbs.
Chassis/Suspension:
4x4 Upgrade: Advanced Four-Wheel Drive Systems (www.advanced4x4vans.com)– Salt Lake City, UT – November 2018
Lift: 3”
Conversion: GM 9325 IFS front differential, 2-speed transfer case w/hi-lo shift-on-the-fly,
Spicer drivelines, torsion bar suspension, heavy-duty front/rear shocks, front anti-lock brake retrofit
Wheels: Gear Mechanic 5 spoke – locking
Tires: BF Goodrich KO2 285/70R/17
Hubs: 8-lug
Brakes:
Upgrade: Z36 14,000 lbs. Truck and Tow Severe Duty drilled and slotted front and back – February 2019
SafeyVan® Upgrades:
Upgrade: All upgrades completed in 2015 prior to initial delivery by Safety Van (www.safetyvans.com)
Tire Pressure Monitoring System
Enhanced-Technology Glass
Steel Safety Cage
Front to Rear Head-Curtain Side Air Bags
Exterior Upgrades:
Bumpers/ladders/roof rack/spare tire carrier and passenger-side rear swing-out: All Aluminess (www.aluminess.com)
Mirrors: Chevy 3500 Commercial Cutaway motorized 30-inch
Headlights: LED Silver LUX® H4
Turn/marker/back-up accent – All upgraded to SuperBright® LED
Fog Lights: Lightronic® 7” round 140W
Light Bar: RoughCountry® X5 52” curved CREE dual row
Light Bar: Rough Country® X5 20” CREE dual row
Cubes: Rough Country® X5 2.5” CREE
Rears: Hella® 550
Camera: Rear View Safety® RVS-770HD hardwired to RVS-6137Q high definition 4-channel display (long-haul trucker suite)
Camera: Parking assist camera rerouted to hitch point (stock remains in license plate housing)
Awning: ARB® Touring 2500mm x 2500mm (8’ x 8’)
Hitch: DrawTite Ultra Frame class IV
Hitch Electrical: New 7/4-pin receptacle
Hitch Electrical: Rear View Safety® Hardwired 4-channel display input
Interior Upgrades
Sound Deadening/Insulation; 5 boxes Noico® 80 mil sound deadening mat applied to all interior walls, floors, roof, and doghouse.
Flooring: New rubber flooring throughout
Sleeping platform/drawers: 48” x 12.75” x 78.75” full-length drawers (2) flex sealed, padded, and carpeted
Sleeping platform/shelf: 68” x 72” with 22” of headroom
Custom Marine Tables (2)
Custom door table
Custom door table mount
Security grating installed on back windows
Custom window covers
Included Extras
Thetford® Chemical toilet in a custom enclosure
Tekonsha® 90195 P3 Electronic Proportional Brake Controller
Back-up alarm (with defeat switch installed)
Hard mounted security boxes (2)
Front-mounted 5,000 lbs. 2” receiver
TRIGGER® 3001 Six Shooter Bluetooth Accessory Control System for all lights
Contact
817.584.8608 phone, text, or email hazii@aol.com
Located in WA state
1st owner – Church in NY (0 – 44,000 miles)
2nd owner – Dealership (44,000 - 45,000 miles)
3rd owner – Current seller (45,000 – present)
The remainder of 100,000-mile GM Warranty remains
60,000-mile GM service performed on 11/5/2019 including all fluids
All receipts and manuals included
All extra parts and fittings included
Carfax Available on request
Title held by USAA
Price: $58,000 OBO
Engine:
Transmission:
Hydra-matic 6L90
Gear ratios 1)
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Chassis/Suspension:
Lift: 3”
Hubs: 8-lug
Brakes:
SafeyVan® Upgrades:
Steel Safety Cage
Exterior Upgrades:
Rears: Hella® 550
Interior Upgrades
Custom door table
Included Extras
Contact
Located in WA state
Title held by USAA
