I outfitted this 4x4 Supercharged long travel tacoma to get off-grid comfortably for extended periods of time. The truck has king shocks, Built Right upper and lowers arms, Custom Deaver leaf pack with under link, custom sway bars, Dev8 front and rear bumpers, A warn 12000lb winch, Baja designs light bars and pods on all four corners of truck.The auxiliary battery system is 2 northstar AGM Batteries powered by two 100W sun power flex panels. The system is also hooked up to the alternator to charge while driving. The spare tire is attached to the cross bar in the bed of the truck. The entire frame of the vehicle is boxed and gusseted for the Long travel and all work was done at The Truck Shop in San Diego. I also have a 10 gallon on demand water tank, two rotopax, ARB air compressor, two ARB awnings with wind pitch and 4 wall bug net, plano rifle case, and 4 max trax. There is a yaesu radio inside and all seats have been covered from day 1 with wet okole seat covers. I also have two gear hammocks by goose gear. One inside cab and one in back of camper shell.
I recently put 4 brand new 35" Toyo R/Ts on, brakes all around and some electrical work.
As is im asking 60K and without all the goodies 40K
