2016 Chevy Silverado LTZ Z71
D45
The V8 sound with the Injen intake and ported throttle body is amazing. Sounds fantastic!
Definitely feels much stronger
D45
Just ordered a custom ported and massaged intake manifold......power hungry
Should be here in a week
D45
So the Silverado bed has the plastic top bed rail caps
The front of the bed, the bulkhead area, is just covered with the factory spray on bedliner.......so there's a decent sized gap in height differences
When in installing a cap, how are people or installers filling in this gap?
Is there a plastic too bed rail trim piece available to install before a cap is set down?
Buddha.
Finally in expo white.
Mine had some kind of 1/8" thick foam under the front "rail" when I took off the tonneau cover. I reused it when I put the cap down.
D45
Thanks
I know they make a hard plastic top trim cap for the front bed rail.......but for the previous generation trucks
I would like to find something other than a foam strip
D45
Westin # 72-11168 is what they sell for older Sierra and Silverado trucks
Hoping to find something for mine similar to this product
D45
Going to look at a used Ranch brand truck cap today......pics later since I likely will buy it
D45
I did buy the Ranch cap for $600
Front sliding window, side vented sliding windows, and frameless rear window
It has an LED third brake light and a battery powered LED light inside.
I need to order a roll of gasket sealing material before I reinstall the cap. There was an extremely thin strip already installed.......that I removed. It was only 1" wide and wasn't event 1/8" thick
The only odd thing about the cap, in my opinion, is the handle or knob on the front sliding window. The handle is on the outside of the window.........normal or not?
D45
The cap is currently off the truck and hanging by ratchet straps in my garage
I ordered a front bulkhead gap sealer strip , made from EPDM for $20
I also ordered two nice rolls of EPDM gasket material for sealing the cap to the bed. One roll is flat and the other roll has two bulbs for compression. They were $60 for both.
I also ordered another adhesive handle for the inside of the front sliding window.
Hopefully everything will be delivered by Monday and I can install the cap permanently mid week.
The cap came with 6 clamps which is nice and solid for a bed under 6 feet. I have seen some 6.5' caps held down by 4 clamps.
I also need to run some power wire from the battery to a 3 hole outlet accessory box that I took off my old truck
Then also install the GM bed tie down hooks and see if I need addtional LED lighting for inside the bed, which is likely
D45
I was thinking about ball joint angles and CV axle angles with lift kits
I ran across Zone Offroad's #ZONC9158 body lift kit for my truck. It's a 1.5" lift for $185 shipped
I could then get a 2" or 2.5" leveling kit and taller rear blocks for $150 shipped.
Both will give me still really good cv axle and ball joint angles and a 3.5" overall lift for under $350
I need to install the cap first to see the how much the bed sags and meadure front and rear fender height differences
Martinjmpr
Wiffleball Batter
Normal. Think about it, if you want to open the sliding window between the pickup cab and the shell, you would likely be inside the truck reaching backwards (through the truck slider) rather than being in the bed of the truck and reaching forward.
It does mean that if you don't have a sliding or opening rear window on your truck you can't open the sliding window on the shell, but why would you want to?
