We're selling our 2017 F550 4x4 with Total Composites 2-bed + 1-bath camper with 31k miles for $349,999.
It's time to move on and let someone else enjoy the outdoors like we did last summer on our trip to Alaska - https://www.instagram.com/arcroamer?igsh=MW1obzhneGd3b2VpYQ==
This truck has a lot of room inside, quite a bit more than similar cab-over setups.
We purchased the truck from August Motors in Kelowna, BC in 2022 and took receipt of the truck in October 2022.
We spent the next 9 months learning the truck+camper and upgrading the systems for a trip to Alaska in summer 2023.
The instagram listed above & the list below detail these upgrades, as almost every system of the truck & camper was changed.
Items marked with an asterisk * were installed after we purchased the truck in fall 2022.
All dimensions are approximate.
2017 F550 XL with 6.7L diesel and 6-speed transmission
*DBL front axle Super60 / Dana 80 hybrid with 6.17 gears + *aluminum diff cover
Dana M300 rear axle with *6.17 gears + *aluminum diff cover (rare)
*20” single piece Nasa Wheels powdercoated black on Continental 335-80R20 MPT81’s
Kelderman air suspension - single front air bag and dual rear air bag with 4-link - https://kelderman.com/shop/2017-ford-f-450-550-c-c-4-link-rear-air-suspension
Hadley SAMS dual compressor + *new solenoid bundle + 4 ride height sensors + *upgraded Parker Hannifin air lines + *upgraded Anderson power quick connect + *75A Blue Sea MRCB
King remote reservoir shocks on the front axle and Ford shocks on the rear axle
*Titan 54-gallon midship fuel tank - https://titanfueltanks.com/products/cab-chassis/7020517
Ford 40-gallon after axle tank
Total Composites box + subframe + storage boxes + bumpers + fenders built by ArcLab in Winnipeg, MB
Front bumper with PIAA amber fog lights and Warn 16.5ti-s 16,500 pound winch with synthetic rope and Factor 55 thimble with *BlueSea 6006 on-off switch + - https://www.warn.com/165tis-heavyweight-winch-97740
Rear bumper with Keeper 17,500 pound winch with synthetic rope & *Factor 55 Prolink XXL with *BlueSea 3000 on-off switch & *500A T fuse + *4/0 Ancor wire - https://www.reese-hitches.com/products/Keeper_KW17_5_12_Volt_Winch,KW17122
Custom side steps
*Upgraded Ford side mirrors for 96-inch panel bodies - 102" Extended Mirrors Available - Ford Truck Enthusiasts Forums (ford-trucks.com)
*Vinyl on hood to minimize sun reflection + *Lensun Solar 65W solar panel (MPPT controller connected to drivers battery)
ARB 12v twin air compressor with *100A Blue Sea MRCB + 8ga Ancor wire - https://store.arbusa.com/twin-motor-onboard-air-compressor-ckmta12/
*Morimoto XB Gen 2 headlights with LaminX film - https://www.morimotohid.com/Ford_Gen_2_Super_Duty_XB_LED_Headlights?quantity=1
*Putco Boss grill - https://www.putco.com/product/boss-grille/v/Ford/F350/2017/
*Rigid Adapt 30” light bar w/o GPS - https://www.rigidindustries.com/adapt-30-230413.html
*LUX lighting 8 piece RGB rock light kit with bluetooth controller - https://luxlightingsystems.com/products/the-monster-led-rock-light?variant=43630713831587
Engine upgrades:
*Banks cold air intake - https://bankspower.com/products/col...f450-6-7l-power-stroke?variant=42326741221573
*Pusher intake - https://pusherintakes.com/pusher-powerflow-2015-2019
*No Limits intercooler – https://nolimitfabrication.com/i-30...6-7-air-to-water-performance-intercooler.html
*H&S hot & cold intercooler pipes - https://hs-motorsports.com/collecti...4-ford-6-7l-hot-side-intercooler-pipe-upgrade
https://hs-motorsports.com/collecti...cooler-pipe-upgrade-kit-black-oem-replacement
*SPE coolant reroute kit - https://www.spemotorsport.com/products/spe-motorsport-coolant-hose-reroute-kit
*BPD oil cooler - https://bulletproofdiesel.com/products/bulletproof-6-7l-ford-oil-cooler-90201157
*AFE oil pan - https://afepower.com/afe-power-46-70322-engine-oil-pan-black-with-machined-fins
*Banks iDash with 4 Datamonster gauges and Pedalmonster - https://bankspower.com/products/data-logger-gauge-66760-all-2008-obdii-can-bus-vehicles
https://bankspower.com/products/ped...-booster-64310c-64313c?variant=40940401295557
*Amsoil remote dual oil filter with EABP bypass filter - https://www.amsoil.com/p/amsoil-ford-6-7l-dual-remote-bypass-system-bmk28/
*SPE internal catch can - https://www.spemotorsport.com/products/ccv-oil-air-separator-fits-2011-2020-6-7l-powerstroke
*Mishimoto CCV catch can with tubing from cylinder head to air intake...drain line to quarter turn valve under driver door
*Odyssey Group 65 PC1750T batteries - https://www.odysseybatteries.com/odyssey/pc1750.html
Espar D2 coolant heater with *EasyStart controller and *Remote+ mounted on center console
EZ Lynk tuner - https://ezlynk.com/
4-inch stainless exhaust
*upgraded fuel tank filling & vent system with dual Atwood vents
*all 4 diesel appliances connect to two Espar dual standpipes in the Titan fuel tank
Transmission upgrades:
*ATS Deep Trans Pan - https://www.lethalperformance.com/a...sion-pan-2011-2016-ford-6-7l-powerstroke.html
*MHX-520 oil cooler plumbed in series after the stock plate cooler - https://www.improvedracing.com/mhx-521-high-efficiency-oil-cooler.html – this helps keep the transmission much cooler than stock
*8AN Fragola HDPE hoses between transmission and stock plate cooler with MPP external cooler adapter - https://www.marylandperformanceproducts.com/products/mpd-11-19-6r140-trans-cooler-adapter
F550 Interior:
*Kingslim D6-4K dash cam hardwired - https://kingslim.net/products/kingslim-d6-4k-dual-dash-cam
Recaro Ergo MCii bucket seats front and rear – front has adjustable air suspension with *seat warmers - https://cdn.recaro-automotive.com/f...s/downloads/recaro-ergo-mcii.pdf?v=1663071769
Kenwood DNX994S radio with front and rear cameras + amplifier beneath center console - https://www.crutchfield.com/S-ZeUN3bwWdxh/p_113DNX994S/Kenwood-Excelon-DNX994S.html
Gamber Johnson center console with Icon IC-2300H & Cobra radios + two locking bins - https://www.gamberjohnson.com/products/vehicle-mounts/console-systems
Alpine TMX-R3300HDMI DVD player w/ remote for rear seats
*BGGD Raptor Steering Wheel + optional heated steering wheel – https://www.boostedgreygoosedesigns...ifter-harness-2015-2020-f-150-wcolumn-shifter
*Dynamat Xtreme & Dynaliner & Havelock wool throughout the cab & doors to minimize sound transference - https://www.dynamat.com/products/dynamat-xtreme-2/
Outbound lockable 23” x 30” pass-thru from cab to camper accessible between the rear seats
Total Composites Camper:
23.5-feet long
84-inch interior height (floor to ceiling)
92-inch interior width (wall-to-wall)
Outbound windows + hatches have sliding bug screens & sliding blackout shades - https://www.outbound.eu/products/windows/
Hatch access to outdoor shower on driver wall
Collapsing aluminum entry stairs with mount on rear wall
Four subframe storage boxes - *Tecniq E32 light added to each box - https://tecniqinc.com/product/E32/
*Camper roof sealed with Korapop 225, then waterproof seam tape, them Liquid Rubber primer, then 8 coats of Liquid Rubber RV sealant
Stainless graywater tank – 60L with drain valve beneath truck + camlock connection with hose
Fiamma electronic awning with controls at door and electrical panel
MORryde Safe-t-rail at entry door - https://www.morryde.com/products/safe-t-rail/
Cabover:
92” x 80”
6” king mattress (73” x 76”) atop Froli kit – 31.5” of headroom between mattress and ceiling (attention to anyone over 6’ tall [I’m 6’-4” and can sit upright without hitting the ceiling] - the headroom allows almost anyone to sit upright on the mattress, making the cabover part of the living area – no other manufacturer appears to offer this) - https://nickleatlantic.com/collections/star
8”D x 17”H x 54”L upper cabinets on passenger side
12.5”D x 13”H x 80”L lower cabinets on driver side
6”D x 6”H x 78”L cabinet along front
Force Provider & OrganizedObie storage above front cabinets
Front two Outbound windows are sealed shut from the outside (that’s how they were when we bought the truck)
*Outbound windows on drivers and passenger allow for supreme cross ventilation (added by Overland Adventure Truck in Summer 2023)
Outbound hatch in ceiling allows for roof access
110V outlet + 12V outlet + red/white light for each side of the bed
Dual 40”x50” curtains on sliding curtain rail attached to the ceiling
Bath:
42” x 27”
MaxxAire Deluxe fan with remote + Rolef fan cover with Camco insulated insert - https://www.maxxair.com/products/fans/maxxfan-deluxe/
Thetford flushing cassette toilet with extra cassette - https://www.thetford.com/products/toilets/cassette-toilets/
Faucet + stainless sink + shower + drain to gray tank
Motion-sensing red light eliminates the need to manually activate a light at night
OrganizedObie storage bins + medicine cabinet - https://www.organizedobie.com/
Walnut slat floor mat
Custom side steps
Engine upgrades:
F550 Interior:
23.5-feet long
Cabover:
92” x 80”
Bath:
42” x 27”
