This is one of the first units sold in the US and is as solid as a rock. This is a pre-covid built unit that is trouble-free (unlike some of the later models). No crazy bells and whistles, just a good solid camper that has been tastefully and thoughtfully upgraded. It does everything you need it to and more. This original model has a higher clearance (over 30") under the 6" box steel frame. The newer units have much less clearance to make way for more for headroom inside. The beefy trailing arm suspension will take you anywhere you want to go. Eurovision windows, AC, 2 Maxx fans, lots of storage (to include handing storage), all the comforts of home.
- Live off grid in luxury for an extended period of time.
600 watts of glass solar panels on top
400 AH Lithium battery from Signature Solar
Victron solar components to include 50/100 MPPT, Smart Shunt, and battery protect
2000 watt inverter
External solar suitcase can plug into Anderson Connector on front of camper
50 gallon fresh water tank
16 gallon triple-filtered drinking water tank
50 gallon gray tank.
You can extend your stay with a 60 gallon external water bladder and pump.
No city water valves to go bad. Just gravity fill the water tanks and you are done.
No black tank to worry about dumping! Is equipped with a cassette toilet that can be dumped in a gas station toilet, vault toilet, or buried. If a cassette toilet isn't to your liking, we have a Wrappon Green toilet that can be included with the sale.
Full queen bed (north/south). Storage galore. Propane furnace, and hot water heater. 3 burner cooktop inside with an oven. Refrigerator is AC or propane and is ice cold! Wired for easy Starlink hook-up! Live off grid and have your internet, too. 24" Visio Smart TV. Did I mention there is a washing machine in the bathroom!
Comes with pull-out external kitchen (sink with hot and cold running water, 3 burner cook top) that has been removed for extra storage but can easily be re-installed.
Top of the line Fiamma 45s awning (not the flimsy off brand electric one that comes with the new BS campers).
Six Sendel wheels with newer BFG KO2 tires (2 are spares mounted on back). Cameras on back and front.
We have spared no expense buying replacement parts from Australia. Equipped with BOS Black Ops tongue jack, all four corners have BOS stabilizers that are actually rated to jack the trailer up, not just stabilize. The hitch is the Hitch EZY from Australia. We have spare parts for the trailing arm suspension underneath and many other parts we've gathered over the years (cabinet handles, window struts, etc).
When this camper is not out exploring, it is stored inside in the RV garage.
You won't find a more capable camper in this class, at this price. $38,900. Can be seen in Southern AZ. Can deliver to a reasonable distance.
2000 watt inverter
