For Sale: 2019 Boreas Campers (ITWO) - Boreas XT
Asking Price: $29,900
My camper needs have changed and I have decided to sell my beloved Boreas XT. I am the original owner and purchased the trailer new in 2019 from B&B RV. It has been garage kept, well maintained, and updated with many of the current model upgrades, see details below. Avoid the waitlist and higher prices on the new campers and get into the backcountry now!
**Financing is available through National Vehicle
Highlighted Upgrades:
New BFG KO2 tires (8/2021 - less than 2000 miles)
New Dexter electric brake assemblies (8/2021)
New wheel bearings (8/2021)
Timbren alignment completed by Boreas campers (5/2021)
Included Accessories:
- Full width front storage box - Installed by Boreas Campers in 2021 ($2600)
- Complete electrical system upgrade (7/2021- $3000+):
- 2x 100Ah Battleborn heated lithium batteries
- Zamp Obsidian 100 watt roof mounted solar panel
- Zamp Obsidian 100 watt portable panel
- Victron 75/15 MPPT solar charge controller (onboard panel)
- Victron 75/15 MPPT solar charge controller (external panel)
- Victron Blue Smart IP67 shore power charger
- Victron BMV-712 battery monitor
- Victron Phoenix 800 watt inverter - 23 Zero Peregrine 180 Awning (9/2021)
- 23 Zero shower enclosure (7/2020)
- MaxxFan 10 speed reversible vent fan with thermostat and remote (7/2020)
- Pre-wired for Starlink
- Digital thermostat for Propex furnace (6/2021)
- USB-A and USB-C w/ PD (60W) chargers
- Mud flaps
- 3”x2”x1/8” CNC cut steel frame - powder coated
- Timbren Axle-less independent suspension - 3500lb HD
- 30” x 9.5” with 4“ lift kit BF Goodrich All Terrain Tires (Ko2)
- 15” steel pro comp wheels - 6x5.5 bolt pattern
- Electric trailer brakes
- Lock and roll hitch coupler
- Tongue jack with rubber wheel
- 7 pin electrical harness
- LED trailer lights with reverse
- 20 gallon water tank with skid plate
- Jeep style fenders with matching diamond plate steps
- Rear crank down levelers
- Full sized spare tire
- Rear 2” receiver hitch (325lbs max)
- Composite and aluminum cabin – No wood!
- Drivers and passenger side entry door with window
- 11lb propane tank with mount
- 200 watts solar panel (upgraded)
- Solar charge controllers with Victron battery management system
- Instant hot water shower
- Custom aluminum roof rack with 2 large
cross bars (500lb max) - Propex HS2000 Forced Air Furnace (6500btu)
- Oversized composite cabinetry
- Composite maple wall paneling
- Fully Insulated walls, roof, and floor
- Interior 12v/USB and 110v plugs (shore power)
- 4 1/2” custom memory foam queen mattress (6’7” head-to-toe)
- Rubber diamond plate floor
- 2 LED side porch lights
- LED interior lighting with dimmer
- LP/CO/fire alarm
- Cargo net storage pockets
- Pullout stainless steel sink
- Pullout stainless steel Dometic 2 burner stove
- Self-priming water pump
- Pull Out 12v/120 CFX40 Dometic refrigerator (Max CFX40)
- Composite cabinetry with interior shelf
- LED lighting with dimmer
- Overhead LED porch light with dimmer
- Kitchen 12v/USB/110V plugs
- Stainless steel counter top
- Fire extinguisher
- Paper towel holder
- Overall length - Tongue to Tail - 15’6” (186”)
- Overall width - Fender to Fender - 7’ (84”)
- Exterior cabin 5’W x 9’2”L x 4’H (60”W x 110”L X 48”H)
- Interior cabin (sleeping area) 4’9”W x 6’7”L x 3’9”H (57”W x 79”L x 45”H)
- Overall height with awning - 6’5”H (77”H)
- Dry weight - 1,950lbs
- Tongue weight - 230lbs
- Rated weight - 3,500lbs
- Water/propane/cargo capacity - 1,550lbs
- 5 gallon portable grey water tank for kitchen sink
- Trimax wheel lock
- Wheel chocks (4)
- 4-way lug wrench
- Indoor/outdoor weather station
