Mountain Goat One
AT Overland Atlas Camper Shell for sale. The entire roof of the AT Atlas camper pops up (not the wedge style camper) giving you nearly 8 feet of headroom when standing in the truck bed. The 2nd part of the platform bed can be stowed in the cab-over section to give you access to the entire bed of the truck with nearly 8 feet of headroom. With bed in place, there is still nearly 3 feet of standing room in the back and you can get in and out of bed without disturbing the person next to you unlike the GFC, Alu-cab, etc. This was a new design made by Atoverland.com and is more comfortable overall, especially for taller people since your head or feet are not in a wedge. Build was completed March 2020 and installed by At Overland in Prescott, AZ. The base model includes the following Standard options:
Asking $14k OBO for camper with all added options. Camper, with all added options (plus tax) was about $18K and I had to wait over 3-months for it to be built and then drive to Prescott, AZ to have installed. I understand the wait is longer now.
DM me for additional pics or info. The rig is currently located in Las Vegas, NV near Red Rock Casino.
Key words (ignore): AT Summit, AT Habitat, Go Fast Camper, GFC, Drifter, Popup camper, Four Wheel Camper, FWC, Hawk, Light weight camper, Offroad camper, Off-Road Camper, Alu-Cab
- Ruggedly designed for 4×4 travel
- Easy 30 second deployment and stowage
- Sleeps 2 standard
- Built in two piece mattress 48” x 80” x 2”
- Insulated sleeping platform and shell walls with carpet covering
- Bedding can remain in place when closed
- All aluminum & composite construction. Roof can be walked on (600 lbs max)
- Locking lift gate
- Built in wiring raceways with double USB port and 12 volt automotive socket
- Interior LED lights (amber colored) and lift gate LED light
- All season tent with no-see-um mesh windows, clear vinyl and privacy panels
- Standard color: Clear coated aluminum
- Base weight: 360 lbs
- Roof weight capacity for accessory loading (i.e bike, kayaks etc.): 100 lbs
- Sleeping platform capacity: 500 lbs
- Painted white to match truck
- 160 watt flexible solar panel mounted to roof (weighs only about 6-lbs) with solar charge controller
- Added side hatch on Drivers side so you can reach items in back of truck without crawling in
- Window (Euro style double pane acrylic) on passenger side with screen and blind
- 270 degree Rhino-Rack awning mounted on passenger side with largest shade coverage in its class
- Maxi-Vent fan on roof that quickly pulls out heat from truck or you can reverse fan and pull air from outside
- Shower / changing room pull-out system added to cab overhang on drivers side
- Roof rack rails (no cross bars as I never used the roof rack)
