2021 Nimbl Camper for Sale
Dirtbagger
2021 Nimbl camper and F350 truck (32K miles) $360K
F350 Truck:
-2021 F350 Super Duty 4X4 Crew Cab, Platinum Trim Package
-7.3L Gas PFI V8 Engine
-10 Speed Automatic, 48 gallon Fuel Tank
-110V/400W Outlet, Adaptive Cruise Control, Particulate Air Filter
-4.3 Electronic-locking Axle
-Carli 2.5” VS Series Remote Reservoir Coilover Conversion Kit (Stage III)
-Carli Pintop kit boasts 2.5” Remote Reservoir King Shocks
-Carli Pintop Sway Bar Drob Brackets and Ford Radius Arm Drop brackets
-Custom Rear Springpacks
-Cooper Discovery AT3 LT285/75R18
-ICON Rebound HD Sation Black Wheels
-Firestone Air bags, ExtremeAire Endura with 4 Gallon Tank
-Dual Air Chucks (located in front jockey boxes each side)
-Power Running Boards and Front Bushwacker Fender Flairs
-Custom front bumper with OEM Fog Lights
-ARB Intensity V2 32 LED Spot Fog Lights
-Comeup 12 Front Wench (synthetic rope, wireless and wired remote control)
-Wheel Well Liners, Upfitter Switches
-Custom Rear Hitch Setup
-OEM installed safe located in cab
-397 amp Alternator and Dual Battery
-3yr/36K Mile bumper to bumper warranty
-5yr/60K powertrain warranty
-5yr/60K roadside assist
-7yr/100K extended warranty (included and transferable)
Nimbl Flatbed:
-Behind Cab Storage with Shelves
-4 Under-bed (jockey) Storage Boxes
-Rear Drawer Pullout with Lid, 8’
-Mounted Shovel
-Custom Rear Bumper with Heated Tail Lights
-Lockable Storage for 4 MaxTrax, (4 MaxTraxs included)
Nimbl Camper:
-Power Systems:
-3 Solar Panels @190 Watts each (total 570 Watts)(25 year warranty)
-3000W Inverter
-3 Lithium Batteries 100Ah each for 300Ah total, 10 year warranty
-Victron Electrical System with Bluetooth control
-Vehicle Charging System Integration through 120A DC-DC Charger
-75 Gallon Heated Fresh Water Tank
-24 Gallon Heated Gray Water Tank
-3-Stage Water Filtration System (carbon & sediment)
Nimbl Cabin:
-Smooth Hydraulic Lift System with manual override
-Two Maxxfan Fans over Kitchen and Shower
-Storage Drawers with Locks
-4.3 Cu Ft 12 Volt Compressor Fridge with Freezer
-Underbed Storage
-2 Reading Lights over bed area
-Memory Foam Sleep System
-Beautiful Mahogany Trim and Floor
-Skylight Over Bed
-Dual Induction cook top
-Shower with Teak Shower Grate
-Multiple Power outlets, 120V, USB
-Heater and Hot Water Heater, Gas (pulls from truck gas tank)
-Cassette Toilet with 5 gallon capacity
-Outdoor Shower and Additional Storage
-Nimbl Custom Awning
-Yakima Fixed Mount System
-Always Garaged When Not In Use
Additional information and pictures available upon request
cogden
Interesting! Is this an XP camper, or a new Nimbl version? Which Camper build # is it? Does it have the Dometic windows or the Arctic Tern ones? What's the full weight, fully loaded and "wet"? What tires & rims are on it? Where are you located. Thanks!
Dirtbagger
This unit was built in 2021 so it is an evolution model. Tires are Cooper and Icon wheels, info above. I’m not sure on weight but estimate 11k lbs with full fresh water. I am located in Littleton, CO. Not sure if build # but can find out.
sam-aye-am
On my XP built rig, there is a sticker on the outside wall (but inside the camper) of the wet bath enclosure, near the floor and entry door. Has date of manufacture, serial number, estimated dry weight, and fresh water capacity. One thing to note on serial numbers is that it doesn't always make sense. Mine says #14 and there is another #14 that is currently for sale on here. I think there might be another duplicate number or two in addition to a couple numbers no one has been able to confirm were actually delivered. And finally, mine normally weighs in at 12.6K lbs loaded for an extended trip. Seems on average most are close to the 12K+ range...though yours does appear to have some of the initial efforts/design modifications to lighten the weight a bit.
Bergger
Great looking rig! Actually my dream vehicle. If it was in the budget I'd snap it up. You did not happen to drive through Leadville today did you? My home town and I either saw yours or one very similar to it.
WonaWarrior
