Ninelitetrip
Not much yet, no pictures. No news on a Hard Wall HBE 8-foot version yet.
Note: There is a Flatbed version and a Fixed version)
Starts At $122,500.00 USD / $ CAD
**Requires OEV HD Aluma Tray sold separate** (Also requires Cab Chassis)
(High Country Hard Wall Fixed Cabin Starts At $146,175.00 USD / $ CAD)
2023 Standard & Optional Features
Interior
• 2.5” high under bed storage plus a 6” queen size mattress
• Snap on vinyl window cover for entry door
• Screen door
• (6) dual pane acrylic windows on the passenger and driver side in the dinette area
• 51” wide driver side/39” wide passenger side (north/south) u-shaped dinette – folds down into bed
• Marine fabrics for all cushions
• 4” medium density foam cushions
• High traffic grade lonseal vinyl flooring
• Powder coated aluminum interior cabinetry (upper and lower)
• 3 ply bamboo countertop and table
• Starboard door and drawer fronts
• Wet bath
• Fire extinguisher (abc)
Exterior
• OEV powder coated aluminum rub rail
• High Country graphics package
Electrical
• (2)-200W roof mounted solar panels
• Victron soc display
• Victron Smart Solar 100/30 mppt controller
• Victron Orion dc/dc charger
• 2000W victron multiplus compact 12/2000/80 inverter (w/charger) w/remote on/off
• Victron cerbo gx colour display w/Bluetooth and tank level indication
• (2)-ac 110v plugs
• LED PS amber exterior side light
• LED exterior DS/Rear light
• LED interior lighting
• 164L dc compressor fridge/freezer
• Smoke/CO/LP detectors
Plumbing/Heating/Cooling
• (1)-multi speed roof vent
• 38-gal freshwater tank w/12v pump and sight gauge
• 15-gal gray water tank (in Cabin)
• Sagiv outside shower connection
• S/S sink w/J-handle faucet and glass top
• S/S single burner propane and removable single burner induction cooktop
• Truma Combi cabin heater
• Thetford C223CS cassette toilet
Options
• Additional pair of 200W solar panels
• Additional multispeed roof fan
• OEV ladder
• OEV molle rack
• Marine roof hatch for over the bed
• OEV front cabin off-road light bar (does not include lights)
• Air conditioning (split system) works in conjunction with chassis compressor (truck must be running)
• Air conditioning (roof mount) – dc powered (dometic coolair rtx 1000)
• Air conditioning (roof mount) – dc powered (dometic coolair rtx 2000)
• Queen bed north/south configuration
• Wrappon toilet – replaces the standard spec thetford cartridge toilet
• Victron 100Ah agm battery (note-std spec does not come with a battery)
• Relion LT100Ah LiFePO4 battery (note-std spec does not come with a battery)
• Lithioncs 320Ah LiFePO4 battery (note-std spec does not come with a battery)
**Note: ALUMA TRAY sold separate**
High Country (Hard Side Removable)
HARD-SIDED REMOVABLE FLATBED CAMPER HIGH COUNTRY (HS REMOVABLE) FULL-SIZE 1 TON DRW TRUCKS Starting at: $122,995 USD Learn More THE TOUGHEST CAMPERS ON THE MARKET The 2024 High Country comes in both a removable and chassis-mounted version. This particular High Country allows you to remove the...
overlandex.com
- External Dimensions 193” L x 81.25” W x 86”
- Internal Dimensions: 190” L x 71.5” W x 80”
- Powder coated aluminum extrusions
- OEV gen 4 composite walls and roof = 1.5” (38.1mm) (<=R8)
1.5” (38.1mm) honeycomb poly propylene floor (>=R5) - DOT LED lighting
- Spec’d for a factory ford F350 or Dodge 3500, 4×4, 60” cab to chassis (diesel or gas)
- Cabin dry weight: tbd
Interior
• Screen door
• Wet bath
Exterior
Electrical
• (2)-ac 110v plugs
Options
• OEV ladder
• OEV molle rack
