20K winch line?
dzzz
Any recommendations? Several companies show rating of 20K plus lines, but don't show stock.
I know amsteel blue has very heavy lines for boats and ships. But I don't see any kitted with a hook. I've only seen cable on tow trucks with hydraulic 20k winches.
Any other suggestion for winching heavier trucks (other than 'don't get stuck')?
At Master-Pull we have multiple lines that are rated over 20,000lbs. Both our 5/16ths Superline and Superline XD are rated at 21,000 lbs, the 3/8ths Superline and Superline XD are rated at 26,500 lbs and the 7/16ths Superline is rated at 40,000 lbs.
-Alex
I'm digging that high performance steel line.
Did a web search, couldn't find a retailer or prices. I imagine it's as expensive as synthetic, but much more durable?
5/16" would be enough for my little 8k winch.
I run 9/16" wire rope on my 20K DP 20AJ in front and 1/2" wire rope on my Superwinch 15K in back.
Check out Python Ultra: about 50% stronger than normal wire rope
http://pythonrope.com/wireropes/wr_python_ultra.shtml
Charlie
A related question:
What's a good hydraulic industrial/tow truck winch other than Ramsey? A high flow winch (as opposed to a power steering hydraulic winch controlled by electronics).
nahuebsch
