villageidiot327
I've got a 2006 E-150
build thread :
http://www.expeditionportal.com/forum/threads/151472-Simple-kind-of-van-a-2006-e150-build-thread
I'm fighting a shake/shimmy and I'm not sure where to go next.......
its got new:
-front springs ---MOOG CC81368
-front and rear bilstein shocks (33-187563/33-176840)
-ball joints
-tie rod ends
-radius arm bushings
-factory caster kit
its been aligned, and rechecked. its "within spec" (can't find my alignment sheet)
it drives nice, much more surefooted than stock, but has a shimmy in the wheel, and the passenger seat shakes (its tight) from about 60-75mph.
now, you might be thinking tire balance..... but i had em balanced like 4 times, and even had the tire shop (work with these guys a lot) warranty the set of tires and try another brand/model. STILL SHAKES/SHIMMY!. they suggested i try another set of wheels, i had bought cheap-o steel D window wheels from summit, so i had them order a set of new wheels, KMC type 301, and while the van drives nicer with the lighter than steel wheels, it still has the shake.
any ideas?
I'm open to suggestions.
-Colby
build thread :
its got new:
-ball joints
-tie rod ends
-factory caster kit
any ideas?
-Colby
