37" Tire Suggestions
D45
My truck is at 9,200 pounds loaded up
I need something in Load E Range
Even if I did go with BFG, the only make a 37x12.50R20, nothing in the 13.50 width I want
Additionally, the BFG Mud-Terrain T/A KM2 is ONLY a Load D Range tire!!!!!!!!!!!!!!!
Darwin
Sounds like sticking with Toyos would be your best bet unless you are looking for a more at type tire. They also have the toyo r/t that comes in 20's.
I second switching to more expo 17's over the 20's based on the 4300 lb load range and personal opinion that they look better than 20's.
leelikesbikes
my load range d 37's are 3525 per tire which is way more than the stock size e's, my point is a d tire ride way better if your truck isnt going to exceed 14k, but if you want an e 37 for a 20 in a 13.50 width you dont have many options, should make it easy for you.
Darwin
I didn't see any Procomp at's in 13.5 inch wide. The Nittos would be one option for something different. It still sounds like toyo M/T's would be your best bet if you want to stick with the dubs.
D45
What about a tire size in "355/60-20"......basically a 37x14.00
Any cons changing over to a P-Metric from an LT?
Nitto makes this size in a Terra Grappler as well as the Falken Wild Peak A/T
It is a Load D Range tire, but is rated at 3,640
My Toyos are Load E and rated for 3,860........not that much of a diff
chet6.7
I would not use a P-metric tire on a truck.
http://www.tirereview.com/tire-types-and-load-capacity/
http://blog.tirerack.com/blog/colintirerackcom/lt-tires-vs-passenger-tires
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=70
http://www.expeditionportal.com/forum/threads/2308-LT-vs-P-Metric
leelikesbikes
did ya look at the link i posted? the pro comps are the first ones that show up for me. ive always been intrigued with them, i think they have a 3ply sidewall, just dont have any firsthand knowledge.
D45
Well I might be staying with the Toyot MTs, that I am a huge fan of
I found this place, who sells 37s at a great price:
https://www.customwheeloffset.com/b...20&diameter_to=20&height_from=37&height_to=37
Four Toyo MTs for $1776:
https://www.customwheeloffset.com/buy-wheel-offset2/360220/toyo-open-country-mt-37x1350r20lt-tires
I am going to print this out and go to Discount Tire, since they price match and offer 0% for 12 months!
I might just stick with the Toyo MTs for this price, since I was quote $515 per tire and now its $444 per tire from this business
D45
I do.....but they need replacing!
Trying a new tire is tempting and would save money......Toyo's are very $$$$
Goldenbora
