3B Diesel RPMs/tire size choices....
MoGas
Central Scrutinizer
I thought I explained this to you already..
No smaller than 33's with the 4.56s and non turbo.
Dave
MoGas
Central Scrutinizer
Besides, I have a set of 33s and a set of 31s mounted up on extra wheels for you to try out before you go and buy some for yourself...Hypothetically, of course.:sombrero:
:safari-rig:
Dave
MoGas
Central Scrutinizer
Someone say LC60 wheels they have?? :safari-rig:
15" factory chromies. I have 5 or 7, I can't remember for sure. It's like a mini Discount tire over at my house. Winter tires/wheels, Summer tires/ wheels, Oz split rims/tires, Mud tires/wheels.
JJackson
Though unlike discount you may have to dig them out of the snow...so when is the lift going on the 60?
davegonz
Here are some numbers taken from a post on Mud that got them off of Specter Offroad.
Peak torque
2F = 210 ft.lbs. @ 1800 rpm
3B = 166 ft.lbs. @ 2200 rpm
2H = 177 ft.lbs. @ 2000 rpm
1HZ = 206 ft. lbs. @ 2200 rpm
Hltoppr
El Gringo Spectacular!
Thanks!
Guess I'll find out tomorrow.... :elkgrin: :ylsmoke::coffeedrink::smiley_drive:
-H-
eleblanc
Let's say, just theoretically for now, that I were to get something with the following:
3B 3.4L Toyota Diesel (non-turbo, 90hp@ 3500rpm)
H55 5 speed transmission (0.84 5th gear ratio)
Stock Transfer Case (1:1 high range)
4.56:1 axle gears
....Running 31" tires would net me about 2923rpm at 70mph, or;
33" tires would net me about 2746rpm at 70mph.
Both tires would be 10.5" wide.
Anyone know what might work better for this motor, with consideration given to mileage and efficiency?
-H-
33" no doubt, usually a Bj42 comes with 4.11 ratio, looks like you have 4.56.
But you will be very happy once you have a turbo installed.
I went through 4.11, 4.88 then back to 4.56 and now turbo. If i would do this again, go straight with a turbo and 4.11 and never look back. Unless you are building a trail rig with 35" and bigger tires.
In what kind of rig this will be installed?
Hltoppr
Did somebody say "road trip?"
....back in Flagstaff...more to come. :elkgrin:
-H-
Goldenbora
