I wanted to start a thread about my Monty build.
Late this summer I bought a 03 Limited with 103K on the odometer. when I bought it the 4x4 would not engage and the traction control would not work.
Here is a list of what I have done so far, still have a long way to go to make it how I want.
New Battery Optima yellow top - mine died when I stopped for lunch 1hour after buying the rig
Replaced the vacuum valves for the 4x4 actuator and walla 4x4 works again - Traction control only works under 40mph still not sure why on that
Put new rubber on- 33" Cooper Discovery
Installed OME lift and shocks
Replaced y pipe - cats were completely gone New O2 sensors all around as well
In process of replacing valve cover gaskets and spark plugs - some one had installed plugs with a .045 gap! manufacture recommends 28 to 35
Also installed water thermostat- it did not have one at all - very odd
Have Rocky Road Rocksliders waiting to be installed -came in today.
I have lots of plans to work on it this winter with a few small trips to get everything dialed in.
