4x4² and lifted G retractable side step at SEMA
Las Vegas G
If anyone is at the SEMA show stop by the Rock-Slide Engineering booth in the South Upper Hall #34131 to see the BRM Portal axle G63 with our new Side step / rock slider / retractable step that will work on the 4x4² or any lifted G wagon!
Features full length retractable step for access to the front and the rear door WITHOUT the need to remove the side exit exhaust pipes!
Strong stainless steel construction.
Does not protrude below the chassis so it does not reduce the ground clearance like other retractable steps!
Produced by Rock-Slide Engineering available exclusively through Bill Rader Motorsports.
Here is a link to the step in action with 420 lbs worth of people on it at the same time! *
https://www.instagram.com/p/Bao45kogIoz/?taken-by=rock_slide_eng
Mitch Bears
