4x4 Class A Motorhome Overland Expedition Camping RV ($25,000)
G35Vortec454
WHOLE or Parts - PARTING IT OUT!!! Also posting in Vehicle Parts.
7/14/23 UPDATED with REMOVED/SOLD parts
https://inlandempire.craigslist.org/pts/d/san-bernardino-4x4-class-motorhome/7641052433.html
Whole price: $25,000
Parts Price minimum: $100
Clean California title; current DMV Registration
Chassis: Ford E350, 158" wheelbase
Engine: Ford 7.5L / 460 ci EFI
Transmission: C6, 3-speed Automatic
ODO Miles: 52,200
Front Axle: 4.30:1 Dana Spicer Super60 Monobeam, Wide-track; Turning Radius: 27ft
Rear Axle: 4.30:1 Spicer S110, Limited-Slip
Transfer Case: NP205, Divorced, Cable-shifted
Body: Class A Motorhome, Rexhall Vision Molded Fiberglass
Dual steering damper kit *********** REMOVED
Suspension: 7.5-inch Lift, Adjustable caster/camber,
Front Coil Sumosprings, Rear Leaf Air Bags ************ REMOVED
Tires: Goodyear G670 RV, 245/70R19.5 on dually wheels
Fuel Tank: 35-gallon tank
Fuel Reserve: 20-gallon tank ******** REMOVED
Propane Tank: 9 gallons
Water Tank: 30 gallons
Waste Tank: 30 gallons
Overall Length: 23 feet
Width: 92 inches
Loaded weight: 12,000lbs
Electrical –
Extra Gauges: Digital- Fuel Pressure, Engine Vacuum, Engine Temp, Transmission Temp, RPM *****REMOVED
Dash-mounted Clock, Weather Sensor, In/Out Temperature, Humidity ***********REMOVED
Dash-mounted LCD monitor for reverse backup camera, push-button forward "watch behind"
250A High-output Alternator
Voltage/Current charging digital meter on dash ****** REMOVED
Adjustable voltage charging on/cutoff digital controller on dash ********* REMOVED
3000W Xantrex Prosine Inverter, with 120A 4-stage charger, remote panel on dash ***********REMOVED
Morningstar Sunsaver Duo solar charge controller with remote panel on dash *******REMOVED
420AH Battery Bank
400W Solar Panels
13.8V Constant-voltage 10A receptacle with USB Fast Chargers ********* REMOVED
240V/120V/12V Inverter Generator, 7000W continuous power
17,500lbs Electric Winch with Synthetic Rope ***********REMOVED
Onboard Electric 150PSI Air Compressor, with 1+5 gallon tanks
High-power auxilliary electric fans, radiator-temp/AC controlled ********** REMOVED
2-step Kwikee Electric Automatic Door Step *************REMOVED
Appliances -
Dash Air-conditioning
13,500btu Dometic Roof Air-conditioner
16,000btu Suburban Furnace Propane heater
5-gallon Propane Water heater
Norcold electric/propane refrigerator-freezer
Dometic Microwave Oven
4-burner Propane Kitchen Range/Stove, Oven
Double-bowl stainless kitchen sink on base cabinets
Conveniences -
Full bed - with memory foam topper, down pillows, sheets, comforter; sleeps 2 adults ******REMOVED
Dinette seating, can be converted to sleep 2 small adults/children
Bathroom – water-flushing toilet, shower stall, and roof vent
Fantastic Vent Automatic Intake/Exhaust Fan, Rain sensor, Remote control
15 Interior cabinets/drawers, with a small wardrobe closet
Sony 7.1ch Soundbar, mounted overhead
200A Subwoofer ***********REMOVED
Mede8er / WD-Play 6-channel Media Players **************REMOVED
Samsung 32-inch Smart/WiFi TV ******************REMOVED
Miscellaneous -
Custom front bumper with sparetire mount *********** REMOVED
Custom rear bumper ********* REMOVED
6 Exterior compartments(3 Passenger side - Generator, Propane, Compressor; 3 Driver side for Tools)
Vehicle-recovery gear toolbox, front bumper-mounted *************REMOVED
2 Lund toolboxes, rear bumper-mounted ****************REMOVED
4G LTE Outdoor Router/WiFi on roof, with dual LPDA directional antennas, manual rotation ******REMOVED
2 new/unmounted Bridgestone 245/70R19.5 tires, Spare new 250A Alternator ***********REMOVED
UPdated
JCCB1998
