4x4 f350 ambulance camper (PureAdventureMobile)
PGGRS
I've run dually's for hundreds of thousands of miles on my Dodge with a Bigfoot 3000 10-11 camper over some very nasty roads including trips up & down the Alcan & Dalton with no issues. Mining roads (rough scree) in Utah & logging roads in the Northwest. In fact I've never talked or heard from anyone who actually had that happen to them. I'd much prefer having two extra tires carrying my weight than the best, highest weight rated single. If you're going to blow that rear single SOME place, it WILL be in the WORST place. I did pick up a screw once on an inner & the only way I even noticed the outer had a bigger bulge at the bottom ( it was carrying all the weight for a while ) Didn't even break out the compressor, plugged it & aired up next town. I'm running Toyo MT's on my ambulance. 255/85/16 with a 1/2" spacer, 34.7 " I believe. About as tall as I'd want to go without changing the gears. 4.56 now. a 37 figure 4.88 at least & any bigger you should go into the 5's. Sometimes "Looks Massive" & cool doesn't work quite that well in the real world (at least mine) Good luck with your build
mitchbenoit
Thanks guys! The wheels are by Hutchinson industries and is a custom set of 20" offset perfectly for a dually truck to run single wheels in the rear. Honestly in the back I have zero lift but do have a nice 3" lift I might add but kind of like how it looks rite now. Still working out the kinks on the inside. Tons of work getting the whole water running, tanks mounted, grey water etc.
patoz
Welcome to the Ambo/Camper club!
Looking good so far, and will be following to see where you go with it.
Houie
