8 ft Pop Up Camper Options?
Op, why is your payload so low?
Just a safe estimate. GVWR is about 8800lbs, dry weight is around 7200 lbs. Full leaf coming up from thuren/carli reduce payload roughly 15%. And other items in the cab and my e-bike. So technically 1300lbs I said above is not the payload, but what I can take for campers and related items.
I see, you went for the ride quality and sacrificed the payload.
Very limiting.. imo
Good luck with your search.
Yes, pretty much. I barely haul something over 500 lbs.
The ride is too stiff for me coming from a 15 4Runner, the lopes on the I-5 is like a trampoline.
Thank you!
I would get a used FWC Grandby. They go for less on the used market because they don't fit 1/2 tons. You may need airbags with the softer springs. Check your GAWR. You have plenty of capacity to carry a slide in. If you want something lighter you may be able to find a 8ft flippac.
Jlbeats
