83 Suburban 6.2 Project
bfdiesel
A little bit of work for the weekend.
Welded a grease fitting protector on the lower bearing plate. Left the old kingpins and replaced everything else.
IMG_0536[1].JPGIMG_0537[1].JPGIMG_0538[1].JPGIMG_0540[2].JPGIMG_0541[2].JPGIMG_0542[2].JPG
bfdiesel
Had some fun with a froze ujoint
Had to compare the 10 bolt axles to the 60's
Then I had to take a break for the weather
bfdiesel
So i cleaneed up the hubs and drilled them out for a bit bigger and longer stud. Next I think I'll pull the rotors off bead blast the hubs, paint them, put new races in. I was going to use the old races and bearings but after I cleaned them up only one looks good enough to reuse, so I might as well do them all.
Last night I got this:
A little oil and it works like new.:wings:
chilliwak
Looks like you have been really :Wow1:productive BF. The truck is looking good and its also good to see you getting out with the kids and dog. Nice pics and thanks for posting...:)
bfdiesel
thanks chilliwak.
So got some more done. Blasted and painted orange for the hubs. Wheel studs work out nice.
Pulled the forged parts I need off the jack I found cleaned them up and painted them too. They will be going on my good jack to replace the stamped steel pieces.
Got some springs. These are from a S10 Blazer 52" offset 24 1/2 x 27 1/2. Should be able to move the axle forward and keep the rear shackle hanger in place. We will see.
bfdiesel
So I am in need of shocks as I go about this axle swap. Which I hope will start back up in a week or two, as the plant's, where I work at, outage draws to a close. I am thinking Bilstien 7100 without the remote reservoir, 14" in the front and 12" in the rear. Any opinions and thoughts welcome.
bfdiesel
So got some time to dig into the baconator again.
Cut off the perches on the 70hd:
Pulled the fuel tank and installed the shackle flip:
The 70hd axle is the longer one 14 bolt is the shorter. Pretty comparable.
Used rachet straps slinging the axle to the frame on each side (tank's idea) to lift, center, and set the angle for the new perches. Welded them in place and bolted the axle in.
Had to see what it will look like once the H1 wheels and tires are on.
I still need to replace all the rear bushings, get the disc brakes mounted, finish my home built shackles, weld on the shock mounts, and measure for the driveline which needs cut down shorter. Then the front will begin.
Also safety first
flipstick
