89 Montero Build: "From Compton to the Con"
Justice R
Ive been wheeling Monteros in one form or another since 1993 when I bought an 86 after a tour in Somalia. Anyways, my latest has been this 89 that I bought out in Phoenix a couple years ago after returning from my second tour in Iraq. I had been wanting to build a short wheel base for a while and my last two had been Long wheel base models. Also, I wanted the 3.0 V6 and and auto trans which is a rather difficult combo to find in the short wheelbase models, with 89 and 90 being the only years of this combo available. I drove my 95 out to AZ with the wife and picked it up. It was in in sorry shape, but I was able to limp it home to So Cal.
Heres a pic from the parking lot, at this point I had already removed some type of wierd roof contraption as well as a cheesey light bar. Note the crome bling stuff and the double blade windshield wipers:wings:
Hey ou think it might be a 4x4??:drool:
Although it was in AZ the truck had cali plates and when I went to the DMV to register it it was still valid in the CA system and was reviously registered in Compton CA.
Took about 3 days with a heat gun to remove all the stickers. There were about 5 differnt pinstripes running the length of the truck.
changed out the hairdryer for a real heat gun, a few beers...progress..
On that last one you can see I took off the unpredictable auto hubs and swapped on a set of superwinch manuals that I picked up online from summit.
Justice R
next
I needed more clearance so I went down the street to Americas tires and got a new set of shoes..cost me more than the truck:sombrero:
15x8 AR Mojaves with 33x12.50 MTR's.
These fit nicely with a little tweak of the tortion bars and little trim of the plastic bumper end caps.
Justice R
next mod
This was by far the most bang for my buck mod I got done. I saw this 96 Montero rear end on Ebay, so I placed a minimum bid of 100 bucks on it. I did not think I would win, but I was the only bidder and scored.
With this bolt in swap I gained the following:
-Larger axles, diff, and ring gear (from 9.0 to 9.5" ring gear)
-Misu air locker
-Rear disk brakes
-beefier trailing arms
Not bad for 100 Bucks eh?? Also the seller gave me the 96 Coils springs for free. I swapped those in for about a 2" boost in the rear.
Old diff out:
New Diff:
Diff in truck:
Justice R
next mod
Since I upgraded the rear brakes to disks I decided to upgrade the fronts to 96 units as well. The gen 2's have Dual piston calipers and a larger shoe.
Stock:
here you can see the difference in hardware. 89 stuff on top, 96 stuff on the bottom:
Complete:
michaels
wow that's actually a sexy truck with all the stickers removed. the paint looks great underneath.
does it have IFS? if so, are there plans for a solid axle swap?
Justice R
next
No plans for a SAS as of yet but I have not ruled it out. The IFS on these rigs is fairly stout (for IFS). Seems to be able to handle up to 35's without much issue. I have some part to beef it up a bit, but I have not yet gotten to that.
removed the T case and installed the 2.85 gears from Marks in AU.
Martinjmpr
Wiffleball Batter
Justice: What kind of shape is the engine in? Has the valve-guide replacement been done or does it burn oil? I had mine done at ~ 139k.
PajEvo
JDM Journeys
Love that truck Justice. I'd never seen the homecoming pics before! :wings: Looks a LOT better now!
Wait'll you see what he did with the bumpers!
Justice R
next
After contemplating I decided on a 2" body lift from 4Crawler to gain a little clearance under the rockers and the ability to move up to 35's in the future. With this I need to move the bumpers up. I decided to scrap the stock bumpers and build a set. I'm a beginner welder, but I think they came out decent. I started with the rear.
2x2 inch square tube..
Naked:
Tacked:
welded:
Cut off the excess stock bumper brackets and trimmed the ends of the frame.
Mounts to the frame using the factory holes
Sliders and front bumper next..
WonaWarrior
