92 4runner 6cyl 2nd gen
I just picked it up last week ( Nov 09) and will be outfitting it for expeditions and DD. My mechanical experience is limited to dirt bikes, VW's and minivans but I am willing to try my hands at anything. I will update this first posting as the truck progresses.
It currently has
150k on Odo, was told motor rebuild 50k miles ago, no info on trans
4" TrailMaster Suspension lift front/rear
4.88 gears
Arb lockers front/rear
All kinds of body damage and gremlins
Compression tested cold 1-6 = 145,135,148,140,145,135 === SPEC IS 142 -171 with a 14 psi diff max between each cyl (testing it warm)
Runs like poo, not safe enough to cruise even around the block - Update= Runs okay now - Update = Runs Great!!
Measured 15.5 mpg on highway
Problems to fix – Many more to come
DONE - Brakes – Rear –inoperative - New shoes/drum
DONE - Brakes – Front – Aggressive wobble while braking - new pads/rotor
DONE - Tires – too loud – Need spare - new 33x9.50x15 BFG AT
DONE - New Plugs,blades,air filter - bosch plat +2
DONE - Idles at 1300? -now at 850rpm - Cables were sticking and adjusted idle screw
DONE - Idler arm – too sloppy - new one with lifetime warranty
DONE - Interior a mess - Interior clean and smelling fresh- hurculiner trunk (1/2 gallon)
DONE - REAR ABS light is always on? - ABS Power Steer Actuator sensor connection was resting on top and not plugged in.
DONE - Rear sway bar bushings and mounts destroyed/stripped - New ones with Grade 8 Hardware
DONE - Spare Tire mount, storage deck, sleep platform, oil filter, oil, atf, diff fluids, belts
DONE - Aisin Manual Hubs
DONE - Gear box (my first real trail carnage) Jan 2010
DONE - Flat Black rattle canned - Jan 2010
DONE - New upper/lower control arm bushings - Jan 2010
DONE - Trans Problem- new fluids, cleaned filter, tested solinoids, Fixed shifting problem - Jan 2010
DONE - New recovery hooks front and rear - Mar 2010
IN PROGRESS -
Needs armor/jack mount/fuel can (havent needed this yet) /tool mounts/winch (not sure if I need a winch) /air/etc (need advice)
Any advice is very much appreciated
From Previous Owner
New Tires / Hurculiner Skirt
Rattle can black/white and Hid fog lights.
It currently has
4.88 gears
IN PROGRESS -
From Previous Owner
