BigDan
Possible new project orientation ,
instead of putting the ram pick up mechanicals in/under the Econoline , I might build an RV out of the pickup ....
this thing is built like a tank : good old fashioned diffs & T/C
It has Dana 60 front diff, positrac Dana 70 rear diff , NP205HD Transfer case
and that 87,000mile first gen Cummins 12V that is totally stock for now .....,
Ideally id remove the 8 feet box , and buy a BigFoot camper that I would fit on the frame and close the sides for mucho storage space & smallgen .....
a cheap earthroamer clone ...
my only problem for now is the front cab bushings are shut and floor pan are rutted nearby them .....
the 93 Ram body parts are scarce .....
the main reason I might do all this is that I was ill for a while and I lost some capacities lately ......It should be simpler to do this then to modify the Econoline ....
advices are welcome
thanks
Dan
advices are welcome
thanks
Dan
