Needin'Advice
Hello everyone,
I am relatively new here, had a thread going in another section, but this is only my 2nd thread creation. I am excited about all of the information here and the collective knowledge among the members. As you can tell by my "name", I will be looking for more answers than I will be providing, but perhaps over time I will be able to offer some info to others as well.
I have a 1994 Toyota Pickup, 4cyl, 5spd, all stock in terms of motor, drivetrain, etc. It has over 200k miles. My problem is that it will start up, but then quickly dies(runs for maybe 5 seconds). I looked at some things online and tried a few things, but to no avail. I will attempt to explain what I have done so far, but please excuse the terminology that I am sure to mess up.
1. Turn key and listen for fuel pump. -- I didn't here it so I did the jumper deal under the hood, and the fuel pump comes on. Start it, it dies
2. Check the intake for cracks or holes -- Didn't see anything obvious
3. Check air filter, try both with and without -- still dies.
4. Removed the Mass Air Flow(?) and check the continuity under various degrees of having the "flap" open and closed across numerous different contacts. Everything was with in a spec sheet that I found online, can't seem to find it again.
5. The only other thing that I read about that I did not try was checking vacuum lines because there are some(at least one) that is unhooked and has a bolt closing it off. It was that way when I bought the truck and it ran, so I never messed with it. I can't think of anything that changed from when the truck ran to when it stopped running. Also, I have no idea what vacuum lines are supposed to do what.
Also, just to be clear, this is a "farm truck" and doesn't go over 25 miles an hour(ag tires) and was only being run every few weeks. It is my winter, driveway truck(as in it is one of the only vehicles that will make it up and down(with chains) when there is snow on the driveway) and I need to get it back in working order. Luckily, I haven't really needed it yet this winter, but I figure the time will come. And, it has been sitting for about 8 months now and if it sits much longer I am sure I will start having other issues pop up.
Please help if you have any insight. Pictures and layman's explanations are welcomed and encouraged. I might have some time this weekend to mess with it, so anything you can provide will help. Thanks.
