97 R50 Pathfinder- Building the dream
mortonm
How did the wiring to the stock fogs go? Was it just simple wire to wire connection or anything more?
Hoping to do the same on my Xterra
Lecoq
Yeah, it's really easy. Black to black and orange to red. You should put 2 in place of each fog light. :)
mortonm
Perfect! Thanks. Why go to all the trouble to wire in power and a switch when Nissan already did the work for me!
Lecoq
Thanks for the link.
Got the OK from the wife on a RTT. So I'm hoping to get it before summer. :wings:
Lecoq
Went on a nice winter run yesterday. It's unbelievable how capable the R50 is with suspension and tires.
XPLOR, Where did you get your gears from? I'm thinking of re-gearing when I do the lockers. What is your MPG like with the 4.56 gears?
XPLORx4
I have 4.636:1 R/P gears from a wrecked '98 SE. There aren't bigger gears available for the R50. My MPG is a pathetically low 15-16mpg, but then again, my rig is heavily weighted, has a virtual parachute on the roof, and wears some heavy shoes, so don't use my MPG as a benchmark!
Lecoq
Is there any markings on the truck that could identify gearing? I can't seem to find anything on mine. It's a 97 SE. Thank you
mortonm
Often there are marking codes on the door jam sticker with paint codes etc for options like that. I don't have any particular experience though for the R50s
XPLORx4
Look on the VIN sticker on your doorjamb, or on the plate on the firewall. Locate the "Axle" code. If it's HG46, you have the 4.636:1 ratio. If it's "HG43" you have the 4.363:1 ratio. It is better to run 4.636:1 gearing with larger tires.
There are no lower gears (higher ratio) than the 4.636:1 available for the R50.
Houie
