98 XJ 5.3 Swap and Other Stuff
stomperxj
Hoooooooood Scooooooop!!!!!!
You know you want to.
Sacrilege!
Seriously though... I really like the clean stock lines of the XJ hood. I've never seen a good looking hood scoop or even cowl hood for an XJ. Plus if I had a scoop/cowl it would ruin my sleeper status :D
K2ZJ
Your's looks good Baja. That's what I should do.... But I probably won't. Airflow makes one that misses the washer bottle in the fender but its kinda ugly. Plus I don't really feel right cutting a hole through a structural part of the inner fender.
With your fab skills you could easily make a brace around it.
stomperxj
I forgot to post it here but I had a problem with the trans again. It is back together and back in. Apparently the over run clutch piston inner seal got damaged on the original install and that in turn burned up the overrun clutches and the forward clutches. $85 in parts and I should be good now:
Overrun Clutches after 900 miles of slipping
Forward clutches:
Overrun clutch piston seal:
Episode 11 is up too if you want to listen to me blab on about things:
https://www.youtube.com/watch?v=zZnUcZD_QA8
lkretvix
