All that oil was from a leaky cam seal when we first got the truck 20,000 miles ago. Apparently they didn't clean any of the oil off the part's when they replaced the seals and timing belt. :/
The belt is dry to the touch. I touched it personally and got zero oil residue or debris on my hands. As for the rest of the insides... LOL... Yes there is oil all over... I asked him to clean up everything with what ever cleaner is safe to spray around the timing belt. Not sure if brake cleaner will cause premature rot or I would have grabbed a can myself! I wiped the accessory brake down with a rag to try to get the clumps of old oil off. Again asked him to spray it all down.
There is an oil leak of some kind at the front of the motor... leaking down by the alternator. I said you have it apart, find the darn leak. Maybe the neck on the oil filler is leaking? I just need it verified its not the cam seals. I have read they can be a beast to get 100%. if its bad fix it while you are in there. I will buy the dang seal!
I asked Saturday if the tensioner and belt were hitting the metal accessory bracket. He said they did not. That he found no wear on either just the plastic. He was so wishy washy about the timing cover... If I can actually get him to replace the cover I'm going to be lucky.... I told him get one from the junkyard if he has to. He is downsizing the shop and freaking about having it there for very long. I told him mitsu said they could get it in a week.... call lkq I said just get it fixed. I'm not comfortable having the belt open to the environment, Esp since I might take it off road soon. He said he would fix it right one way or the other...
Talked to the shop owners wife just now. She was not happy that he suggested a junk yard part to replace the timing cover that was damaged. She got the Mitsu part number from me and is going to see about getting a new one ASAP!
So good news there!
