@Adrifters - F550 Surf Camper Build - Adrift Motorhome
S2DM
I’m not sure, I ordered it through a friend who has a flooring store and he did the order. The color is citron if that helps narrow down what it is.
I have a entry door Mat from them as well that has a very heavy duty backing. This is lighter, but still has a nice amount of cushioning underfoot
racer3822
Checked out the video, nice to see it all put together. Been following your thread for years now, great job with the build! Motivating me to get mine painted.
Lwing
Just read complete thread, great persistence to get where you need to be, glad your girlfriend stuck around for the 5 year build, that's a feat in itself.
DiploStrat
Most, most impressive. As a total composting toilet phanboi, l love your doorway installation, especially with the shower integration. Much better than anything I have ever dreamed up!
Lwing
Would you mind sharing what springs you ended up with and what was on there previously, about to start my subframe and it's pretty hard to find info on where to start. I'll have a 12' camper on an E450 just guessing around 5000lbs, and any info on thought process on how you figured out would be appreciated
Thanks
S2DM
Thanks
The fronts were a set of f250
Carlis I shaved 1” off of, that gave a final lift height on the front of 1.5”. Really smooth compared to stock. And the rears were a custom pack from deaver. I had to make a second set out of thicker steel as the first was undersized and ended up being too loose even after adding two leafs.
I’d get your final weight then do the spring packs so you have some real numbers for them. It’s still guess work and personal preference. While it was time consuming the deavers vastly improved the ride.
S2DM
I think I've become a little overconfident in what the truck can do and it bit us on the way out. The day before we'd come in on an incredible narrow and steep cart path that would have challenged a tacoma and had my Mrs. covering her eyes. On the way out, through all the really hairy stuff, and 1 mile from the freeway, the road collapsed on us.
Doesn't look that bad from this angle, but the truck was actively slipping and the angle was getting closer and closer to roll thirty. Managed to wedge a rock under the tire to stop the slip, but trying to manage something like this with a kiddo was pretty stressful.
CharlieGreenT
