We took the truck on its first extended trip up to Sacramento. Before we left I slapped a 30" FTE resonator/muffler on to kill the straight pipe rumble and it works beautifully. It installed easily and has just the right amount of exhaust note. there were no issues with the truck and it averaged a little over 20mpg, despite the trip computer claiming 23+. It did, however, become readily apparent that keeping the wondering frontend out of the next lane was quite exhausting after a few hours and thus the front end has been receiving quite a bit of attention lately.
I ordered up the Mopar steering upgrade kit for '08-'10 models (p/n 52122362AH) which has a 1.5" tie rod that puts the stocker to shame. I had planned to do the 99HD steering and had it on hand since there is some confusion as to which model trucks require which. After breaking the old linkage apart and comparing the tie rods it was obvious that the tapers of the 99HD did not match up and so I slapped on the Mopar one which bolted right up. The only issue was the passenger rim rubbed slightly on the tie rod, but it was nothing the grinder couldn't take care of.
While I was at it I also installed a DT Profab 3rd gen track bar and conversion bracket. I opted for the upgraded bearing on the frame side which has a larger 1" end instead of a 7/8" heim.
The install was pretty straight forward. The bar is very stout and the bracket bolts on very easily. It required drilling two holes in the cross member in addition to using the factory track bar mount.
I did learn that Big Trucks need Big Tools and that what works on my BMW resto won't cut it on the Dodge. I had to pick up a 250 ftlb torque wrench as my little one was useless for the truck. For instance the jam nuts on the trackbar are spec'd at 525 ft.lbs. So I created these torque wrench extension from some giant Harbor Freight wrenches and c channel.
Next I decided to create a steering brace based on the Dodge Off Road brace. I decided to start with a PSC brace that I got cheap on ebay and use it as my starting point, which was good because when I mocked it up in its original form it did not fit at all. I hacked it apart and built it from some 3/16" and 1/4" plate. The design ties the steering box to only one side of the frame instead of spanning the two frame rails so that frame flex does not exert any force on the steering box.
Tacked together
Welded up
Test Fit
Add some SEM undercoating
Done!
Even have a place to mount my crankcase breather tube!
Thuren 2" coils and his Overland shocks are waiting for the weekend to be installed.
