Finlayforprez
Hello Everyone,
I know this may have been discussed elsewhere, but I can't seem to find specifics. I contacted the folks at BFG and they just state that I should use the manufacturer's recommended numbers. For the US LR4 those numbers are 36 front / 42 rear (this is for the 19" standard wheel option). I put 18" Compomotive wheels on my LR4 with BF Goodrich A/T KOs in size 265/65R18. I'm not looking for tire advice, but more so some thoughts on the optimal pressure. The max PSI is 80, and I have heard of guys running 40-50 psi with luck, and it makes sense to have something around in the middle, but it depends on the vehicle's weight and other factors.
My LR4 is a bit heavier than stock as I have the following added weight:
- Full-size Urban Offroad rack with the spare tire on the roof and a permanent Pelican box with about 30 pounds of supplies
- Tactical 4x4 rock sliders, gas tank skid plate, and transfer case skid plate
- ARB front bumper with WARN winch (metal line)
A lot of the weight is distributed evenly with the rock sliders and skid plates, but all of these modifications add a fair amount of weight. With that in mind, and what I have heard from others running BFG A/T KOs, I am doing 44 front / 48 rear. My tire wear seems to great, no issues with handling, but I am always curious if I should be doing something different.
Thanks in advance for your comments.
Regards, David
Here is a pic of it that someone took - it's actually clean:
Regards, David
