You guys are funny
Random thoughts:
The point for us is to get people thinking, last year we built a crew cab "luxury" truck, this year we went no nonsense utility, figured we'd leave it to people to connect the dots and figure out that they could build something somewhere in between that fits their needs...Want a crew cab version of this years truck, no problem...thats the nice thing about the Ram's...their are hundreds of options to please everyone.
I ordered a truck for this build but it got here 5 days before SEMA, so I had to find a truck on the lot in NY...the electric transfer case..yeah that was a surprise, I have no idea why you can get that paired with a manual trans...but here it is. Seemed to work fine.
The bed floor is 7" higher than the standard bed. Everything is a tradeoff, if we had gone with 37s it could be lower of course. Add a Four Wheel Camper, you have the higher height, but you could offset that by using the space under for your water tank and actually end up with something with a pretty low CG. You also gain a ton of room on the sides compared to a traditional slide in unit.
Just drove this rig 1400 miles home from Vegas via Moab and Jackson Hole. The swampers are louder than a BFG, but truck drives great, I'm used to the Iroks, run them on most of my personal vehicles, they're better than you would think on the road for what they are. Wheeled a little bit in Moab, the rear is far too stiff unloaded and wheel travel was limited by that, it kept tending to pick up a rear, but that can all be dialed in depending on need. If there was a FWC on the back, it would have been fine I think. Might need some rear disconnects
Manual trans combined with Cummins, Air Lockers and 41s aired down to 25psi made climbing about anything ridiculously easy. Snow in Jackson wasn't too deep, but driving along in 12-14" was unnoticeable.
Truck only got 15mpg on the way home (75mph) but we started with 95 miles on the engine, they don't tend to get good mileage till about 20K. The red 3500 w 37s (auto) we had with us got 18.6 on a drive from Durango to Moab one night, so I expect this one to settle in around 17-18mpg with the swampers.
This bed is 8.5' long I believe. Going to be perfect for two sleds.
I think thats all.
dh
