Aftermarket Part Origins
vectorsc
Very few Chinese car parts have turned out well for me, and there is little method of telling where this stuff was made without ordering it. As such -I bring you the Aftermarket Part Origins Thread!
I hope for this thread to possibly become a sticky in time. Please post here parts you have received aftermarket and what their country of origin is. Please don't post commentary other than related to the part you received - I'd like this to be as high calorie as possible.
Please note that parts suppliers change the origin frequently so this list is by no means authoritative.
Label/Maker: Raybestos Professional
Description: Front Control Arm, Passenger
Part Number: 502-1188
Country of Origin: Taiwan
Additional Note: Much better made than the same Chinese part.
Description: Front Control Arm, Driver
Part Number: 507-1372
Label/Maker: Beck/Arnley
Description: Lower Control Arm Bushing, Set
Part Number: 101-6314
Description: Ball Joint, Upper
Part Number: 500-1079
Country of Origin: Japan (555)
Label/Maker: GMB
Description: U-Joint for Front Shaft
Part Number: 220-0081
Country of Origin: China
Label/Maker: GMB
Part Number: 215-0081
Additional Note: Much better made than the 220 series U-Joint.
Label/Maker: KYB
Description: Mono-Max Shocks, Montero, Front and Rear Set
Part Number:
vectorsc
Yes - there is. Most parts suppliers will change the parts numbers at least when their factory line changes. It gives you a pretty good chance of getting a part that wasn't made in China. It is a warning though that it may not all work out perfectly.
vectorsc
Updates:
DEA transmission mount
Made in Thailand
Seemed to be good quality
Additional update on the Raybestos control arms - they had the exact same flaw as the Chinese arms - unusable weld nuts for the bump stops. They were so far off center I had mill the arms to get a bolt to fit.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Mitch Bears
