Air Options...
jeffy
Not true. It has changed ownership. Brad Kilby had two companies and only time for one so he sold the Kilby company.
That's right, it changed ownership but there hasn't been any word from the new owner if and when production will resume. Most of the big stores have stopped listing KE stuff so getting one might be difficult. So if the OP needs it now, he's a bit SOL.
Ron B
a correction --
I put down the wrong model Viair a few pages back -- I have the 480c (200 psi) not the 460c (150 psi). It is not the fastest pump around but I use it to keep a 5 gal tank full, not fill tires directly (takes about 10 min to fill a 5 gal tank from 0 to 200 psi) so filling tires is quick and easy. There's a 490c coming out soon that will do the same in half the time.
These compressors can't comparer to the Kilby's (I checked their page -- very cool!) but do well, hold up under severe conditions and are relatively inexpensive.
wjeeper
Just my experience with my CO2 set up I have right now................. I liked that it was fairly cheap initially. You can just buy a beverage CO2 tank, a regulator, a hose and a fire extinguisher bracket and you have essentially the same set up as other "store bought" CO2 systems for less that half the cost.
I have a fancy adjustable regulator. I set it at 130 psi and haven't ever adjusted it yet. Also it has two gauges, kinda pointless because its always left at 130 psi and the tank pressure gauge doesn't give you an indication of tank level. The only way to tell how much is left in the tank is to weigh it. So all the features of the fancy regulator don't really matter to me.
Its light and simple. No fuses, wires, solenoids, PRV's, A/c style clutch and other things to go wrong. I sometimes use it as a shielding gas for my welder when my 75/25 runs out on the weekends.......and you can use it with a beer keg:sombrero:
Having the tanks filled is a major annoyance, just another thing you have to run out and do while your getting ready for your trip. Also everybody always wants to use it to air up back after a trip, making the gas go faster and the trips to fill it come more often. People always ask if they can borrow it.......lent it out once and it came back all scratched up:mad: The portability between vehicles is nice, mine has been in three rigs now.
All in all I like the set up but if I were to do it all over again i think I would go with a York pump based system. The benifits of unlimited air without annoying refills beckons to me:drool:
TOTJ
Brad decided to stop selling to the big stores long a go. They wanted all the profit and Brad found that selling direct was much better for him and he could control prices. He kept a few of the original dealers but it was only 2 or 3.
Woods
Just found this thread and I wanted to add one detail. Yes the Viair 450 is slow. I recommend the 400C by Viair. It's much faster and has plenty of duty cycle for the JK. I fill my 35" tires on 15" rims from 9 PSI to 27 PSI in about ten minutes. Here's a link the my compressor torture test: TORTURE TEST
nwoods
Wow how weird. Another Woods from SoCal...with the same opinion!
Woods
Classic. I see that you hang a bit with the MJR guys. I've wheeled with some of those guys in JV.
Is Onyx Peak closed now? Did the entrance used to be directly across from the Burns Canyon road at the 38? I was there a couple of days ago and walked over the dirt pile too check it out.
What city you in?
nwoods
I'm in Yorba Linda. I recently sold our Jeep, but went up Onxy Peak last fall with no problems. Entry is on west side of 38 right at top of summit, opposite a large dirt staging area.
Woods
I'm in Costa Mesa. Found Onyx Summit on the map. Looks like it's down the 39 at Pipes Canyon Rd.
Sorry bout the hi-jack here. Now back to our previously scheduled programming.
rdonahe
Another C02 guy here. I purchased a tank & regulator used from a reputable local source, then hose & fittings at Lowes and am into it roughly $150. I've only had cheap 12V compressors prior to this so I can't compare to York etc., but the C02 is easy and fast, fast, fast.
Goldenbora
