Alaskan Camper Build Up
Carlyle
Thanks Brad!
I just finished putting two coats of wax on the rest of the camper and truck. You don't realize how much there is to polish until you are half way through...
At least it's one of those projects that gives you instant gratification, though my wife just doesn't understand.
The Adam Blaster
Hey Carlyle, i don't how feasible it is at this point, but would you be willing/able to put a list of sources where you sourced out most of the cool options you chose for your build?
I think that would be a pretty good reference for others that are considering a similar project in the future. ;)
wild1
Yakima racks
I really like your track system, much more versatile then the one from Alaskan. Are the tracks bolted all the way through the roof to the inside or are they lagged into the roof framing?
Carlyle
Hi wild1, I went ahead and had Alaskan attach the Yakima tracks to the roof frames with lag bolts so that the big plastic nuts that come with the tracks were not showing inside. It looks much cleaner that way. I agree the Yakima track are very versatile.
Carlyle
Adam Blaster, as promised here is my list of sources that I have come up with thus far:
Camper Build up Sources
1. Solar Vents: Sunsei Solar Vent Stainless Steel http://www.icpsolar.com/4105/home.asp
2. Solar panels, voltage regulator and remote digital monitor: http://www.rvsolarelectric.com/
3. Wifi Antenna: Model #WAVERV http://www.radiolabs.com/
4. Satellite Radio antenna: Terk SIR6 Sirius Outdoor Home Antenna http://www.amazon.com/
5. Nova Kool 5.7 cu ft 12 volt fridge: http://www.boatelectric.com/Nova R5800.htm
6. 2500 cfm under settee AC: http://golittleguy.com
7. All outside LED lights: http://www.superbrightleds.com/
8. 22" Sharp Flat screen LCD: http://www.amazon.com/
9. JVC in dash CD/DVD player with built in amp: http://www.ebay.com/
10. Kenwood 6.5" speaker X 4: Local car stereo dealer who did install
11. Viper alarm system in truck and camper: Local car stereo dealer who did install
12. 9' Aluminum Flatbed: http://www.uteltd.com/
13. Leather for Settee: http://www.weleather.com/catalog/
14. 16.2 gallon Manchester LP tank: Local LP dealer
15. 3 aluminum under-bed Jobox: http://www.buyautotruckaccessories.com/
16. Inside LED lights: http://www.abimarine.com
17. Yakima racks: http://www.rei.com/
18. Outback FX2012MTcharger/inverter, Mate 2 digital controller, Hub and Flexnet DC: Ordered by Alaskan from Seattle rep.
19. Energy 1 NSB210FT AGM batteries: www.llsupplyco.net
20. Linear Actuators for TV lift: http://www.firgelliauto.com/
21. PIAA back up lights: http://www.truckaddons.com
22. Quick Fist clamps for fly rods: http://www.endroad.com
23. Awnings: Carefree of Colorado at J.D.L. TRAILER SALES, Pueblo, CO
24. Gun vault for valuables: http://www.cheaperthandirt.com
Carlyle
Thanks for the encouragement everyone!
I've been doing a few fine tuning projects over the last couple weeks to make camping a little more pleasurable.
Steps are directly bolted to the rear of the camper and have a rod that holds them up in place that pins in place for safety on the road. Works great and much more stable.
High pressure propane is tee'd off and run to a quick disconnect to allow easy use of barbecue and outside stove.
Quick disconnect on gray water tank, the shut off valve on the coupler keeps the gray water hose from dripping spuge when not connected to the tank.
Low tech solution to bottom door pinching finger etc when it swings in the wind. Bungee cord attached to wire holders. Top one slides up and down to allow for top going up and down. This should be standard on all Alaskans.
Anchor points on flatbed side to allow for attachment of cool Thule table.
Carlyle
And an extra step added to the bottom of the camper so that getting on top when the top is up is not a rock climbing experience...
Carlyle
Hi Brad,
The steps are made by Step Up Manufacturing out of Eugene, OR. The set we have are wider and deeper than the typical steps that come with a truck camper, and thus more stable.
lkretvix
