Alu-Cab Has Landed In The USA!
Troyercd
Gobi Stealth + Shadow Awn installation notes
I've been building up my JKUR over the past year as an overlanding platform. My most recent mod was the RTT and awning. For those interested in this configuration, below are my install notes/pics for the Shadow Awn and Gobi stealth. Hopefully this helps. There are a lot of great roof rack, RTT, & awning options out there. Just personal preference, I started with the Gobi stealth and went from there.
BLUF:
1. Attach the Shadow Awn to the top tubular bar (1"). Due to the Gobi design, the awning doesn't have enough clearance if attached to the lower bar (1.25" tube) when fully opened. (Trust me, I tried multiple ways).
2. I used modular mounts from Fourtreks that grab into the tubular bars. Works great, no slippage. http://fourtreks.com/modular_awning_mounts.html
3. Front to rear positioning is key. Again, the Gobi design doesn't allow for much tolerance. The awning location (front to back) requires precise positioning in order to clear any obstructions. See photos.
4. No ladder. I ended up needing to remove my Gobi ladder for the install (obstruction). I didn't try to put it back on, as I no longer need it to access the top. More importantly, it's extra weight that I don't need.
After two days of trial, error, and testing during install, I'm quite satisfied with the results. Install is likely a bit easier on a different style rack, but I like the Gobi look and it works well for me.
BONUS: With the RTT (James Baroud Evo) mounted, my rooftop Maxtrax storage location was suddenly gone. I wasn't sure where I would mount them, but discovered that I could make use of the Gobi rear side tubular bar and the modular clamps. (I had ordered both 1" and 1.25" clamps while working thru the mounting process).
Rig in use:
Shadow Awn stowed:
Shadow Awn deployed:
Fourtreks modular clamps:
Hinge view and clearances 1:
Hinge view and clearances 2:
Hinge view and clearances 3:
BONUS: Using the Gobi rear vertical side bar as a mounting point for the Maxtrax. I used two 1.25" modular clamps in combination with the Maxtrax mount. The tracks are mounted using only the right side of the track. To make sure they don't flutter in the wind at high speeds, I also used a gear tie on the left side of the track to secure it to the bar.
Topo.Ranger
BLUF:
Rig in use:
Shadow Awn stowed:
Would you be able to use the ladder made for the other side of the rack?
Troyercd
Yes, I believe you could use the Gobi ladder on the side opposite of the awning. The original issue was the 45 degree angle of the awning support member, which was hitting up against the lower bar and ladder area in the rear. It's also worth noting that I chose the driver side for my awning application. The reason why is because on the Jeep, the spare tire swings out towards the passenger side. Having the awning also swing from the driver side to the rear towards the passenger side follows the same path as the spare. Result: unimpeded walk thru. Otherwise, you'd have to walk around the tire every time. Each vehicle type will have its own optimum configuration.
Topo.Ranger
I would get the driver side mounted awning also. my tire carrier swings towards the passenger side, and once i get my RTT i will have it fold out towards the passenger side so i could use that as a small awning.
harbinger808
Much Mahalo to OK4WD for taking the time and showing the ins and outs of the ShadowAwning at Expo West. I'm taking it in tomorrow to Sierra Expeditions here in PHX and they will mount it up to my Prospeed roof rack using the Prospeed awning mounts. Hopefully, its a pretty straight forward install once the clearance for the rear hatch is measured up.
Can't wait to start using it on family trips :)
el_topu
Was the canopy on display in OEX West for 2nd gen Tacoma? Any pictures?
LandCruiserPhil
Yes the Tacoma was present along with Rino
Very nice construction and detail
As expected much more durable than other composite tents
First pic is there tip down fridge slide
Didnt get any pics of the nice 270° awning requiring no support legs and we had the wind to test it.
el_topu
:drool::drool::drool::drool::drool:
m(a)ce
we've been testing the Alu-Cab RTT & Shadow Awning.
so far impressed with the build quality & attention to detail of the RTT and completely spoiled how easily the awning deploys/stows in addition to extra coverage it offers.
irish_11
Random, but any word if you are going to be carrying Alu-Cabs truck canopies too? Curious what an Explorer canopy would cost in the US? I saw a few in Aus last fall and really like the function and construction.
rino
Approved Vendor - OK4WD
They are coming in time, we will be sending a few vehicles in the near future to South Africa for fitment. Tacoma 2nd and 3rd generations are our main focus.
Coming this July we will have production Tacoma 2nd / 3rd Canopies for Short / Long bed available in black and silver. We will also have the Expedition III roof top tent back in stock now in silver and black and lastly we will have our first shipment of the ICARUS roof conversions for the D110.
daveh
Matt, how does it feel or effect handling in regards to the weight compared to the Baroud that you had on there previously? Do you know the total weight of tent and awning?
jesus m anderson
