Aluminum vs steel bumper thoughts.
Aluminum vs steel bumper thoughts here is some information you may want to consider or not.
There is a lot to be considered. I, for one, am always trying to save weight and have good placement of weight with my vehicle. Reason for me is that I have a lot of stuff and stuff adds up in weight quickly so if I can keep the base vehicle weight down as much as possible this will help with gross weight. (base vehicle weight is including all things that are attached and part of vehicle, bumpers, armour, etc.) Plus excess weight out past axles is never a great thing. Having worked with aluminum in the marine world a fair amount it is definitely worth considering for bumpers. It takes knowing how to build structure.
If you are thinking that you don’t plan to ever see rocks then aluminum would be fine because it is softer then steel so it will not hold up to this abuse like steel, this depends on series of aluminum also. You also need to consider if you live in a location that salts the roads. A lot of people think aluminum does not corrode since it does not rust. Well it does, a lot of it has to do with the dissimilar metals. Such as having an aluminum bumper bolted to a steel frame with steel bolts, add an electrolyte such as salt or de-icer, and you will get galvanic corrosion and your aluminum bumper will become the sacrificial anode in the equation if not properly isolated. Proper isolation of bumper mounting would be necessary, I am pretty positive that most truck fabricators are not real familiar with this topic and say oh that won’t happen, but …I know better. I could go on for days on this subject with my aluminum, marine electronics/mechanical background. Aluminum skids or sliders do not make any sense unless someone made them with UHMW attached to the aluminum. I chose the steel tube hybrid option, strong and saves weight.
Cam-shaft
