Speaking of closed minds, maybe you missed the memo but Texas is not all desert and cactus, and we don't ride horses to work.
Never mind that I live adjacent to 675,000 acres of National Forest, well within hurricane and tornado country. Do share with us where you live, and I can make equally blind, uneducated, naive statements about your state and its terrain, climate, and topography. Or is there some other reason why you don't share that info in your profile?
EDIT: Oh, you're Canadian...
I'm quite aware that Texas has forests. I can't however, understand how somebody who has ever been in a forest would think a chainsaw is a bad idea to carry, so I assume Texas forest must have some magical quality in which the trees never fall. That is why I stated you must not live in
boreal forest. Which you don't.
With the work I do I'm often in the woods so my FJ stays packed most of the time. Adding a chainsaw to the mix 100% of the time would take up even more space and leave less space for people and other gear.
I only take the saw when I'm specifically going on a trail cleanup day prior to an organized event. However, it's not uncommon to clear a trail one weekend, and then by the next weekend, it's blocked again.
Otherwise, the axe is good enough.
I've got one of those and found the same thing, I have a large knife that cuts better. I wouldn't recommend it to anyone.
Oh, it cuts well. My thumb is evidence to that! They show a technique where you grasp the brush at the top with one hand, and use the hook to cut it at the base. Only it didn't cut, and slid up into my thumb... It was sharp enough the wound left no scar.
Can't say the same about a hi-lift jack, having sold mine years ago, but I would consider a rig out in the "boonies" without an axe and a shovel to be unprepared.
Yep, but I still see it way too often. I'm usually the only one out there with an axe. I've had people say "Well, I guess we have to turn around" "Oh, an axe? That'll take hours." 1 minute later "Ok, wow, that was fast."
And to whoever called out cutting through a 3' tree with an axe - I'd like to see that! Sounds like a strongman competition!
Nope, just time. (not me)
If there's a tree in the way, you can always turn around or try a different route. It doesn't immobilize you.
What if the tree is between you and home? It's like the argument against snorkels "I just don't drive through rivers." Then you get out there, a storm comes in, flash flood, now there's a river where you crossed a dry bed on the way in.
The Pulaski or "P-tool" gets my vote. Renders a shovel obsolete for vehicle extraction
Maybe in some places. Not where I am.
BTW, here is the saw used to fell that same tree. Do you really want to carry that around? (And they still needed an axe to cut wedge out anyway)
