I have a Land Rover LR3. Roof is mostly glass, but there is a section in between the front and middle sun roof that I would like to place either a 1/4 wave whip or puck style GMRS antenna to meet ground plane requirements.
I’ll be using a 15w Midland mobile GMRS unit. My goal is to achieve results that are no less than a hand held used in the cabin, which is what most of my group uses. My problem (I think) is that I will eventually install a Front Runner or ARB base rack style roof rack that I anticipate would cover the puck, and if I went 6” whip, would likely stick up through one of the slats on the rack. Roof rack could possibly have a roof top tent, but at a minimum, would have various storage boxes, fuel cans, etc.
Has anyone done something similar that could comment on performance? I’m not trying to accomplish maximum performance, but logic says there will be a lot of interference and I don’t want to drill a hole in my roof and then have worse performance than a handheld in the cabin.
Mounting on the rack itself is a better solution, I’m sure, but I don’t want to wait, nor am I interested in a re-wire. Lip mount on hood is another option, just not the look I’m after, so really hoping the roof location I’ve described will be good enough.
Thoughts?
Thoughts?
