Another Gen1 Tundra Thread
smokeysevin
Re-redoing things the third time
Where did you get the longer end links from? I am really close to just saying screw it and fabbing a set.
Sean
AaronK
They're factory as far as I know. Unless the previous owner put longer ones on for some reason. Don't know why they would have though, truck was bone stock when I got it
Sent from my OnePlus One using Tapatalk.
AaronK
Nice job on the sliders.
Evolution Prototype and Design here in WA did the design and most of the work. They did a fantastic job. Per my specification, they made them beefy as hell. Main rectangle tube rock rail is 0.188" wall and the round tube is 0.120. 95 lb each
toyotech
Wow. So heavy. Why such heavy duty?
AaronK
Because what is life if not to live in excess 😛
Got them installed today! Took a lot of work and had to go buy a new drill that would fit between the frame and body. But they turned out great
wrenchMonkey_
Sliders look great. My design is the same, but I used 2x2x10GA for the main frame rail instead of 3/16. Mainly because that's what I had on me. Tube is all .120 DOM. I am looking at around 60-70lbs per side.
toyotech
Considering the loaded weight on a Tundra, over-building a set of sliders is probably a good thing.
True but sliders are only as strong as the frame they are welded too. In the tundras case, it's not that strong lol.
rickashay
I know that some sliders will help reinforce the face of the frame rail. When Cruisin Offroad built mine, they actually ran pull plating up the entire side of the frame and wrapped it around the bottom of the frame rail. I am quite certain they are the beefiest sliders I've ever come across, but like Jose said, I think the extra support on the frame side makes it worth it. The Tundra frames are a little flimsy.
AaronK
In hindsight something like that would have probably been better. Distribute the forces along the whole frame... We'll see what happens
wrenchMonkey_
That's what I did on my sliders. I am using 2x2x10GA to mount it to the frame. 4 mounts per side of 2x2 would give me roughly 16in square of welding surface. I put on some 4x6x.250 plates, with a 1in lip, much like a fish plate. Gives me 96 inches of wieldable area on the frame. Much better at distributing the load across the frame.
As you can see, hard angle to weld on. Upside down and overhead. Fun stuff.
Clemtiger84
