Antique Land Cruiser on the road since 2003
eleblanc
The two axles painted and ready to roll in place under the frame.
Coen
Wow, sway bar in the rear?, never though there was a sway bar on any of the 40 serie trucks....my Bj42 doesn't have one, must be a 45 LWB thing.
x32792
Interesting Mind Set
??? I'm not sure I follow your comment. The 7.50x16 is probably the most common 4x4 tire in the world. By a wide margin.
If you wonder that Coen et al rarely put their vehicle in 4WD, that is not surprising. Most of the roads in the world are better, and worse, than you expect. But even in the Third World, they tend to be pass/fail. If you can get through, then any tire and 2WD will work. If not, then nothing will work and you wait for the dry season. Really.
Interesting mind set. I just finished a 6,000 mile run across the USA; 3,500 miles on the gps plotted Trans America Trail. The mind set which comes with running this predominately dual sport motorcycle trail is more, "Damn the conditions, I'm going thru!"
Familiar with 3rd world. I was a Peace Corp Vol several hundred years ago and have been on foot throughout most of Central and South America.
Older and hopefully wiser, I am now just dipping my toe into "overlanding" and expedition travel.
My recent trip was done in a stock '01 Jeep Wrangler Sport and I rarely used my 4x4. I had no wench to pull me thru a single 1/4 miles section that turned me back and my 30" A/T tires only failed me once... on ice.
John
landcruising
Excellent posts, I enjoy the updates every time,
will it be baptised with a llama foetus sacrifice or just a couple of guinea pigs washed down with corn ale ?
Hope to do a ritual at the Titicaca lake lateron.
Yep..
Unfortunately your front leafs are too short, i doubt even with the weight of the engine that shackle will get verticale. Keep a eye on that, if the shackle are not near verticale the ride will be stiff.
The weight [3.000 kilos] will set it all Okay, I will show you when it gets to that...
John
Asia saw more 4x4 action for us. Jungle, rainforest and rivers. But remote Brazilian spots and snow in the Andes got there share as well. But these things are rare and it is not a ever lasting 4x4 battle for us, but our way of living and transportation. Like said before, we drive roads, but we aren't afraid of adventure like the Dakar dune trails in Chili....
Coen
landcruising
The raised part of the roof is going to be in coffee.
The tire carrier and asorts are being painted.
The raised section is getting attached.
Alex is getting the wheels off. The rims are getting sanded and painted.
I am trying to get the stainless steel bumper shiny and to mount the tow hooks and winch.
Getting some more protective asphalt paint on the inside.
x32792
Looking Good!
Looking good as all the parts and pieces are being put back together. How long has the restoration taken?
landcruising
this is what you were looking for...:sombrero:
Just got these figures from Karin-Marijke:
Landcruising Adventure Some facts and figures:
- Overhaul took exactly 100 days
- Based on an 8-hour workday:
* Coen worked 617 hours
* All mechanics together 922 hours
* KM 294 hours
- Total costs 6000 US dollars:
* workshop for overhaul bodywork + extra work like 2nd dieseltank, support for spare tyre etc 3000 US dollars
* all costs for spare parts, material, tools etc 3000 US dollars
Coen
x32792
Witches' Market
If you have time for a break, you and your wife might enjoy a visit to the Witches' Market?
landcruising
Workshop = 3,000,-
Parts & materials = 3,000.-
Total = 6,000.-
Adventurous greetings,
Coen
landcruising
Karin-Marijke buys some new brake shoes for the rear.
And I am cleaning the adjustment system. Funny In my book they show as two with different directional threads. I have two similar turning ones.
Karin-Marijke cleaned and varnished the floor and is preparing to install it again. How convenient like this without the roof.
Let's have a look. How was it again?
Another view of La Paz.
coen
Jim K in PA
coen
Coen - are the automatic or manual adjusting rear brakes? Make sure you have the correct ones if they are automatic adjusting. If you have one threaded the wrong way, it will LOOSEN the adjustment rather than tighten as they wear. Perhaps one of LC gurus here on the Portal will chime in (I am just a lowly Jeep guy . . . :) )
landcruising
Hey Jim,
These are the manual adjusting types. So maybe the automatic ones are the ones that are mirrored?
Jim K in PA
Coen-I would have guessed that they were manual adjusters as the "teeth" on the star wheel are square, rather than angled or "saw tooth" shaped. The auto adjusters would be mirrored, typically. Again, I am not a Toyota expert. With your manual units I would not worry either way.
Have you worked out the tank switching schema yet?
JPT4648
