So as most projects do, I started researching air bags and ended up looking a 2-3K in suspension as my searching progressed. Based on a lot of my research I'll hit some high notes and ask for peoples opinions on the subject..
Things to consider.. At this point I daily drive the truck (2008 F350 Crew Cab Long bed on 37s) and probably will still drive it around. Meaning it won't be a dedicated expo truck, it'll have to be a multi use. Hence why I don't just want to add airbags for heavy loads only. The right setup could ride like a dream stock all the way up to GVW.
1. Only way an Airbag betters the ride is to remove leafs from the factory spring setup
2. removing leafs greatly increases the need for traction bars
3. traction bars kill ground clearance and break over
4. Considering running an all airbag parallel 4-link setup like the one in the picture below... a triangulated 4-link also crossed my mind but I believe this would not be the most road friendly However I have NO experience with a triangulated system.
Concerns... Lateral forces / articulation with a moderately heavy load off-road.
So what do you guys have to say about all this? Any suggestions?
